I'm looking for a gamepad for Android, which will mostly be used for playing emulated games from NES, SNES and Gameboy (both regular and Advance). I'd like it to have some kind of clamp so I can attach my phone to it so it doesn't have to go in my lap. Does anyone have a recommendation?
https://linustechtips.com/topic/503691-bluetooth-gamepad-for-android/
https://www.google.ca/search?q=android+controller&biw=1920&bih=1075&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjVleqwtdXJAhXwqIMKHTZwCm8Q_AUIBigB
http://www.mogaanywhere.com/
probably the best
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
