you just did a video comparing the Asus Z87 Maximus VI Extreme vs the Gigabyte Z87N-WIFI.  both of these have z87 chipsets in them so i would have guess that they would of performed the same.
My question is:
how does different Chipsets affect performance of the games?
testing FX 8350 with the 990FX and the 970 Chipset.  both of these chipsets have different bus bandwidths (5200MT/s and 4800MT/s) and different number of PCIe lanes (x16/x16/x4/x4 and x16/x4).
i do not know the Intel bandwidths to the chipset but how do the Bx5, Hx7, and Zx7 (x being 7 or 8) affect performance.  (i do know that there are boards with the x16/x4 PCIe lanes and other with multiple x16 PCIe Lanes)
possibly also do crossfire/sli testing with lower end chipsets that offer x16/x4 PCIe lanes and see how that compares to a better chipset that has x16/x16 PCIe lanes.
Thanks Linus and Slick, i found your youtube Channel because i seen a recommended video (a wan show) that had Logan from Tek syndicate in it, subscribed ever since.  i decided to make  profile on the forums because of the question i posed above.  thanks especially if you answer
ps. i am looking at getting a FX 8350 processor with an ASUS M5A97 R2.0 ($262 with CPU/mobo) or a ASUS M5A99FX PRO R2.0 ($312 with CPU/mobo).  so this question is a little more appropriate for me than how do 2 boards with the same chipset differ.  i am leaning to the 990FX because of a better PCIe lanes and better VRM for the 140w+ FX 8350.
CPU: AMD FX8350 CPU Cooler Zalman CNPS 12x Motherboard Asus M5A99FX Pro R2 GPU RX480 4GB) Memory 16GB DDR1333 SSD: PNY Prevail 120G + Corsair Force LE 120G (Steam) Bulk storage Stable Bit Drive Pool with 5x 2TB 2x 3TB PSU Corsair 600w Case Rosewill Throne
https://linustechtips.com/topic/50343-question-for-linus/
Linus might not see this, if you want to ask directly from him you can just send him a PM  :)
https://linustechtips.com/topic/50343-question-for-linus/#findComment-671462
There are already benchmarks regarding pci-e slots and how much they affect gpus.
http://www.tomshardware.com/reviews/pcie-geforce-gtx-480-x16-x8-x4,2696-9.html
http://www.techpowerup.com/reviews/Intel/Ivy_Bridge_PCI-Express_Scaling/23.html
Basically, stay pci-e 2.0 x16,  pci-e 3.0 x8, or above for each lane and you'll be fine.
Disregard the chipset. There are varying differences. Just check the pci-e slots. A good way to tell if they meet this requirement is if they are 'sli ready' since that basically means they are 3.0 x8 lanes or better.
https://linustechtips.com/topic/50343-question-for-linus/#findComment-671469
Chipsets do not really affect game performance.  At this point they are basically just I/O controllers for your USB and SATA.  The GPU and CPU communicate through the PCI Express bus which is a direct path between the two.  The chipsets do have a few secondary PCIe lanes, but those are used for ethernet or other I/O, or the x1 slots on the boards.  They are not used for x16 slots.
https://linustechtips.com/topic/50343-question-for-linus/#findComment-671470
Whoa, first post and already a question to mr. tech tips himself. Aiming high ^^
Intel 4770k@4.6GHz, ASUS ROG Maximus VI Hero, Kingston HyperX Beast 2x8GB 2400MHz CL11, Gigabyte GTX 1070 Gaming, Kingston HyperX 3k 240GB - RAID0 (2x120Gb), 2xWD 1TB (Blue and Green), Corsair H100i, Corsair AX860, CoolerMaster HAF X, ASUS STRIX Tactic pro, Logitech G400S, HyperX Cloud II, Logitech X530, Acer Predator X34.
https://linustechtips.com/topic/50343-question-for-linus/#findComment-671531
Thanks,
i do not know how the x16/x4 SLI would perform.  all of those test were with x8/x8 and x16/x16 and there was a small performance hit from one to the other.  I would imagine that a x4 in the mix would only affect performance even more than those.
The main difference between chipsets in terms of performance these days is whether they are overclocking-enabled days
Thanks Linus,
i was just thinking that the 4800MT/s vs 5200MT/s would have difference performance.  Although very minimal i would think more quantifiable than different boards with the same chipset.  Also i have not been able to find good benchmarks comparing the different chipsets with the same CPU, and figured it would be a good review for a reviewer like your self to do.
Thanks, Twitter gave it wings.
https://linustechtips.com/topic/50343-question-for-linus/#findComment-676252
