I'm trying to setup a data and voice modem and every time it says your device has been activated and I go to a new tab it is like nope activate it again -_-
Call their support line.
 CHRISTIAN MEMBER
i did and it said all your devices have been activated and nope still not working
Did you get a person or a machine.
By your answer I would say machine. Try and get a person if you can.
Are you able to access your modems admin page?
*edit
what equipment do you have?
 CHRISTIAN MEMBER
i would suggest you check your connections i had similar issues and i found it to be loose connections so i would make sure that everything is connected. after that my modem activated properly. also make sure its connected on a line that has no splitters and or the least amount of spliters
Please Quote so i know you have replied. | If we have provided a solution to your problem mark it with answer found.
And also please read the COC and avoid the embarrassment and lecture that will ensue.
