Check with CPU-Z. Sometimes Windows gets the CPU speed messed up. Mine shows my CPU is running at 3.75GHz when in fact it as at 4.5GHz. If CPU-Z also shows the same reading it is teh correct one and your CPU is simply downclocking to reserve power.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/503020-cpu-speed-issues/#findComment-6716367
Tried CPU-Z and it looks much better. 4699.7 MHz
Breaking things 1 day at a time
https://linustechtips.com/topic/503020-cpu-speed-issues/#findComment-6716394
Then you have nothing to worry about, just Windows is acting up, as always.
https://linustechtips.com/topic/503020-cpu-speed-issues/#findComment-6716401
