So i just made the switch from a mac to windows and i just encountered an issue i nvr had on a mac. Usually when having skype calls i just plug my earpiece that comes with a mic into the headphone jack on my imac and both the mic and earpiece work no problem. but now on windows, if i plug my earpiece into the headphone jack the mic won't work? is this a hardware or software issue and how can i fix it?
CPU: Intel i5 6500 Motherboard: Asus H170M-E D3 Memory: Kingston HyperX Fury DDR3 2x8 GB GPU: -NIL- SSD: Samsung 850 Evo 250GB HDD: HGST Deststar NAS 3TB Case: Corsair 240 Air Power Supply: Seasonic M12II Evo 620W Display: Dell U2515H 25" 2560x1440 Keyboard: Corsair Strafe (Red LED + Cherry MX Brown) Mouse: Logitech Performance MX Speaker: Edifier M1360 2.1
https://linustechtips.com/topic/502689-audiomic-issue/
Is it even compatible? Is it driverless? If not, do you have the right drivers? Can you select the audio device in Control Panel?
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/502689-audiomic-issue/#findComment-6712040
It's a hardware "problem". A regular mic jack won't work with a 4 pole jack connector, so your computer simply don't pick up the signal from the mic.
The fix would be to get a 4 pole splitter http://www.amazon.com/StarTech-MUYHSFMM-Headset-Splitter-Adapter/dp/B0058DOWH6/ref=sr_1_1?s=electronics&ie=UTF8&qid=1449761573&sr=1-1&keywords=4+pole+splitter
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/502689-audiomic-issue/#findComment-6712058
i honestly have no idea hahahaha
how do i check all these?? I mean it works with my phone, mac and every other device so why not a pc?
this is the one im using if it helps http://www.skullcandy.com/earbuds/5050.html
https://linustechtips.com/topic/502689-audiomic-issue/#findComment-6712089
Your jack probably doesn't support mic input.
https://linustechtips.com/topic/502689-audiomic-issue/#findComment-6712111
Is your pc laptop or desktop? Most smaller form factor laptops have combo audio jacks which should work like iMac. Larger laptops and all desktops have separate jacks for speakers and mic. If thats the case, you need to get separate mic or separator for signals (if one exists).
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/502689-audiomic-issue/#findComment-6712632
