Brands and Items for Portable&Backup Storage
Solved by Captain_WD,
~snip~
Hey there Canto666Hades Welcome to the community!
Are you looking for internal drives or external ones?
For internal backup drives I would recommend checking out WD Green. These drives save energy, work pretty quiet and are designed for secondary storage and backups. Here's a link: http://products.wdc.com/support/kb.ashx?id=rT9hjT . I wouldn't consider storing a copy of your data on the same computer a backup, though.
For external drives, what I would recommend, I would suggest either checking out a external HDD (either portable or desktop) or a NAS. Both can store your data from multiple systems but the latter one can be accessed by multiple devices at the same time and even from phones/tablets, etc. Here are some suggestions:
WD Elements Desktop: http://products.wdc.com/support/kb.ashx?id=OipSto
WD Elements Portable: http://products.wdc.com/support/kb.ashx?id=lFaKfc
WD My Cloud: http://products.wdc.com/support/kb.ashx?id=HsOXoC
I would be useful if you specified a bit what you are looking to do and get.
Captain_WD.
