Hey so this is what I want to do.
I want to use the same drive for an external media library and internally as a os expansion for installed games.
My problem.
Everytime I use it externally and format it. I'll then put it in my hotswap bay (Haf XB). Windows prompts me to format it in order for it to use
I've tried partitioning it doesn't work.
I was wondering is it possible to use a harddrive Internally when you want and externally when you want. Without having to format. I've now tried NTFS formats and FAT32 to achieve this and neither have worked
Thank you!
https://linustechtips.com/topic/50235-hard-drive-internal-and-external/
Hot Swap enabeled in BIOS?
Or you could get an external eSata drive. Barely any difference with a mechanical HDD. What I do. Huge tower no room because of rads =P
Frost upon these cigarettes.... lipstick on the window pane...
I didn't see the Hot Swap Enable option in my bios? I'm assuming it is because the drive is detected Its just prompting me to format
