I want to build a pc, but with a low bugdet because I live in Portugal and I don't have too much money and the pc parts in here are overpriced.
I have an ideia for a build but I need help to see if this is a good build.
pcpartpicker:http://pcpartpicker.com/p/3GRk23
And sorry if the post is bad structured is my first post here  :)
https://linustechtips.com/topic/502058-building-my-first-pc/
First of all, welcome to the forums!
About the build: Get some i3 CPU and an AMD GPU (since you don't have one now?)
The PSU is overkill. You'll be fine with 500W
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/502058-building-my-first-pc/#findComment-6703129
Well, if this is for gaming, that wouldn't be the best choice of components '
I usually try to steer people away from the FX line of CPU's for the time being, and you have no GPU
What will you be using it for?
https://linustechtips.com/topic/502058-building-my-first-pc/#findComment-6703136
If you can save up for it, something like this would be better
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.88 @ OutletPC)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($45.98 @ OutletPC)
Memory: *Pareema 8GB (2 x 4GB) DDR3-1600 Memory  ($29.99 @ Newegg)
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Drive  ($44.99 @ Amazon)
Video Card: *Sapphire Radeon R9 380 4GB NITRO Dual-X OC Video Card  ($178.98 @ Newegg)
Case: Xion XON-310_BK MicroATX Mid Tower Case  ($25.98 @ Newegg)
Power Supply: Thermaltake 500W 80+ Bronze Certified ATX Power Supply  ($27.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($89.88 @ OutletPC)
Total: $618.67
Generated by PCPartPicker 2015-12-09 09:30 EST-0500
Also, make sure you follow your own topics so you can see when people reply :) @Gamer_Fenomenal
https://linustechtips.com/topic/502058-building-my-first-pc/#findComment-6703172
Thank for the reply I wasn't sure if I will buy second hand GPU or a new one, and for the looks I should change the CPU to intel insted of a AMD, I and the build of the stupidtiggers is a good one and you already tried @Stupidtiggers because like I said Portugal isn't a good place to buy parts and the shipping some times is too expensieve so I need something not to expensive or not to bad.
And I'm pertending for gaming.
https://linustechtips.com/topic/502058-building-my-first-pc/#findComment-6703252
