Currently looking for some decent higher airflow case fans.
Front intake = 3 x 140mm
rear exhaust = 1x 140mm
Looking at these two.
Corsair AF140 LED
66.4 CFM
25.5 dBA
1200 RPM
Corsair AF140
67.8 CFM
24 dBA
1150 RPM
The LED's would add some colour to my case with it having a large side window, but performance wise is there much difference between.
Any thoughts?
https://linustechtips.com/topic/501610-case-fans/
Did look at noctua, nf a14 pwm fans, but i'm not sure how they are interms of unrestricted front intake
And buy an LED strip for the lighting.
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/501610-case-fans/#findComment-6697441
I have 3x NF-A14 PWM's in my case, 4x technically because the CPU fan is one just with a different frame.
Decided to get them because of how bad the Arc Midi R2 fans were, and why not because they'd match my CPU cooler from Noctua.
Ditched that shit case and have a Enthoo Pro M now
They're good fans
https://linustechtips.com/topic/501610-case-fans/#findComment-6697500
They're good fans
how do the fans perform? really well?. And are they loud or fairly quiet
https://linustechtips.com/topic/501610-case-fans/#findComment-6697526
You have never used delta fans. 12000rpm and can get louder than 85db.
Eveyone who has used or knows about Delta fans also know that they're loud, which is fine since they are made to move a ton of air + they don't claim to be silent nor does anyone expect them to be.
https://linustechtips.com/topic/501610-case-fans/#findComment-6697599
