I am planning on making a PC sometime in the future and I needed help choosing a case.
I want something small to medium sized (for example a small mid tower or an Matx tower)
I would like for it to be simple and elegant with tasteful accents (for example Corsair Obsidian or Fractal Design)
I need a window
5.25 in bays aren't required, but would be nice
I will be getting an AIO so, I will need space for that.
I will be planning on having SLI in the future with an expansion card
Also, it cant be that expensive. (I cant spend $160<)
Finally, silence isn't required but would be nice.
Thank you for all the help!
(P.S. Sorry for sounding like i am filling out an order)
https://linustechtips.com/topic/501260-need-help-with-case/
NZXT S340 or H440.  Corsair 100R,200R,400R.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/501260-need-help-with-case/#findComment-6692692
Those are good options, but if I were to get any corsair case it would be from the obsidian line up
I would go with the NZXT because I don't see the price premium justified in the Obsidian line up.
https://linustechtips.com/topic/501260-need-help-with-case/#findComment-6707563
I think the 450D is a pretty solid case for its price, nothing too fancy, just a good old Obsidian quality. I think its $120 right now in neweeg.
https://linustechtips.com/topic/501260-need-help-with-case/#findComment-6707711
I agree but it's hard to beat the S340 at $70
https://linustechtips.com/topic/501260-need-help-with-case/#findComment-6707801
Is the S340 good for air cooling? or should you only consider it if you are watercooling your system? Since the space to intake air is so small?
Fractal define s is a much better watercooling case.  The S340 doesn't have terrible airflow though.
https://linustechtips.com/topic/501260-need-help-with-case/#findComment-6708012
