Seagate Enterprise 6tb V.4(SAS) vs WD red 6tb(SATA)
I have a friend that wants to sell me at unopened Seagate Enterprise 6tb V.4 and if I buy this pci controller then it will be more or less the same price as if I go out and buy a new 6 TB WD Red Hardisk.
I don't really have a lot of experience with Enterprise disks or SAS Disks but considering what the Seagate Enterprise disk would cost for a new one it should be the better deal I think.
So the question is if you think I should buy the WD red or Seagate Enterprise disk + controller?
And if I buy the Seagate disk is it then an ok controller I have found? I know it is "only" 6Gbps but that should be more than enough right?
it is for a upcoming "plex + more server" that is going to take the place of my old Synology NAS.
Hmm, if the price is good, then I would go for the enterprise Seagate. SAS hard drives aren't cheap. My 4TB WD Re SAS drives cost me $250 a piece.
However, the controller card you linked wouldn't work. SAS 12Gb/s uses a different connector than SAS 6Gb/s. You can adapt 6Gb/s drives to a SAS 12Gb/s RAID / HBA card, but not the other way around (At least to my knowledge...maybe you might be lucky to find a convertor cable somewhere. You need a SFF-8087 to the SFF-8643). You should look at the LSI 9300-8i HBA card instead. It's better to keep the RAID / HBA card the same or newer than the drives for compatibility issues.
I would check warranty though. I hope you'll be able to keep the warranty / register it. I kind of would like to see SMART data / know if the drive isn't DOA before buying if there's no warranty.
