Small power supply
Go to solution Solved by Thermite,
does that power supply fit in a standard atx power supply slot? If not does it have an adapter that comes with it?
I have a lian li tu200 and I want a smaller power supply that is fully modular. Can I get some recommendations on a good power supply. I want it to be as quiet as possible. I have a x99 motherboard with an i7 5820k processor, and a 660ti graphics card.
This is my opinion, it doesn't mean I'm right and is liable to change at any time. I may offend of which I apologize in advance.
(Our lord and savior: GabeN)
https://linustechtips.com/topic/501134-small-power-supply/
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/501134-small-power-supply/#findComment-6691241
Isn't there a 700W SFX-L coming out?
Soon...
https://linustechtips.com/topic/501134-small-power-supply/#findComment-6691250
Yeah, the Strider is a good option.
By the way, isn't the 660ti a little underpowered for an x99 build?
Yea I don't game a lot but I can utilize the cpu so it just kinda worked out that way.
https://linustechtips.com/topic/501134-small-power-supply/#findComment-6691261
https://linustechtips.com/topic/501134-small-power-supply/#findComment-6691284
