Hi forum,
I wanted to jump back into Witcher 3 after Heart of Stone got released. I have two 980ti's in SLI and the performance is worrying. I know that the witcher 3 is one of the best optimized games out there and I can distintively remember than when I had two 970s in SLI it was maxing them at 90% average for both. When I set sli for the 980ti's however, they seem to stay around 50% all the time. On a single card I get 99% usage. Things I've tried:
-PCIE power options
-Turning off vsync
-Setting SLI to max performance
Halp. I have a 144hz monitor.
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/501009-witcher-3-sli-problem/
I assume your fps isn't good as well? Try disabling SLI and run the game on one card, should also be plenty to run it well
FX-6300 cooled by Nepton 240M | EVGA GTX 970 SuperClocked | 8GB G.Skill ValueRAM | Cooler Master 690 III | Sharkoon WMP 500 Bronze
Power supplies:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ My F@h stats: http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=zyntaxable Intel vs. FX for gaming: http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
https://linustechtips.com/topic/501009-witcher-3-sli-problem/#findComment-6689499
Thanks for the input but I have two cards for a reason. To run it at minimum 100FPS.
https://linustechtips.com/topic/501009-witcher-3-sli-problem/#findComment-6689513
i'm not too sure about it but could it be your i7-4820k?
Even Jayz from JayzTwoCents said that he believes his i7-5960x bottlenecked his 3 way Titan X setup.
So that's my best guess.
>i7
>bottleneck
Pls. The game barely uses 50% CPU.
https://linustechtips.com/topic/501009-witcher-3-sli-problem/#findComment-6690268
>i7
>bottleneck
i don't have Witcher 3 to test with but from my experience when the GPU usage isn't maxed out it tends to be the CPU's fault.
I Could be totally wrong though,like i said it is my guess.
Does the 50% GPU usage thing happens on other games like maybe GTA V?
And have you tried running the game on the dual 980 ti on another system?
https://linustechtips.com/topic/501009-witcher-3-sli-problem/#findComment-6690738
