Unbalanced Sound Sennheiser 598s
Solved by SSL,
if it is common with these headphones should i just return them and get some other headphones?
One last thing to check. Did you try putting the headphones on backwards? That can ensure that it isn't your hearing.
I'd also try it with multiple devices if you can.
Finally, use the tests here to confirm with the above: http://www.audiocheck.net/soundtests_headphones.php
These headphones are worth exchanging.
Featured Topics
Tamgam12 ·
remo233 ·
Posted in New Builds and Planning7 -
1
6
10
rickymohk ·
Posted in General Discussion3 -
Rbakker02 ·
Posted in General Discussion1 -
BaidDSB ·
Posted in General Discussion5 -
2
