A little icon problem
Go to solution Solved by Mr. Chairman,
I hava a question and possible answer to your question.
First mine: what is that little thing on right side of your screen that says "System" and looks like a bunch of cool stats?
Now to your problem. This looks like Stardock modified system. Is it?
If you're running Icon Packager try restoring to defaut that specific icon. I know it has that option. Your second shot is reinstalling whatever program is responsible for your icons.
This issue has nothing to do with your GPU, it's simply impossible. It'a a software problem. What icon is that anyway? Maybe try to reinstall that program...
""picture"" this happened before a problem happened to my GPU the icons (some of them) changed into the default theme and after the GPU incident when plugged back the GPU and started my computer the icons on my taskbar changed into that unavailable symbol on the picture
can somebody please tell what can i do to fix it
and the problem that happened to my GPU >>>>>>>http://linustechtips.com/main/topic/44020-please-help/#entry576457<<<<<<<
spec
copy past of my signature
Casethermaltake M5 MB: ASUS M4A785TD-V EVO |CPU:AMD Phenom II X4 955 Black Edition |
  Graphics card Radeon HD 4870RAM: kingston  8192 MB DDR3 Dual Channel| Storage: 1tb WD hdd,Monitor: sony tv 32 inch
 and window 7 ultimate 64bit  :rolleyes:
and is there some sort of app that can fix this
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/50067-a-little-icon-problem/
You seem to have a heavily modded system no clue what could be causing that icon to not show correctly.
https://linustechtips.com/topic/50067-a-little-icon-problem/#findComment-667361
Remove and reapply all of your desktop/theme modifications. I had the same problem after my video driver crashed about 50 times in a row, and my card died.
I'm not an audiophile, I'm just really picky about my music... and my headphones... and my speakers... and my microphone. Other than that, I'm totally not an audiophile.
https://linustechtips.com/topic/50067-a-little-icon-problem/#findComment-667492
If you are using Rainmeter, make sure you don't hav anything that is conflicting with your desktop icons. It has happened to me before.
-Corsair 750D - MSI Mpower Z77 - 3570k @ 4.21 -Corsair H60- 8GB Corsair Vengeance 2133 Mhz- Corsair RM850 - MSI 780 Lightning -256GB SSD- 2 1TB HDDs - LG 23' Flatron - Razer Death Adder - Ducky Shine 3 Cherry MX Blue - Logitech z506 5.1-
Project - Bloody Lightning
https://linustechtips.com/topic/50067-a-little-icon-problem/#findComment-668490
ok i will try that
ExSystems
https://linustechtips.com/topic/50067-a-little-icon-problem/#findComment-669145
my desktop icons are fine,the folder icons are the problem and i don't keep anything on my desktop
ExSystems
https://linustechtips.com/topic/50067-a-little-icon-problem/#findComment-669152
Does the problem still occur if you disable Rainmeter?
https://linustechtips.com/topic/50067-a-little-icon-problem/#findComment-669233
yes it still do
ExSystems
https://linustechtips.com/topic/50067-a-little-icon-problem/#findComment-669564
in the list of shells is there something not belonging there because the 1st time in happened was because of some app that could put album art on my music collection and after my trial was finish uninstalled it and it was long time ago i cant use a restore point anymore
ExSystems
https://linustechtips.com/topic/50067-a-little-icon-problem/#findComment-669586
"Never trust anyone and rely on your instincts" - If you know who said it, you're awesome
https://linustechtips.com/topic/50067-a-little-icon-problem/#findComment-669616
Oh, I see from that screenshot it's Icon Packager. good, I use it too, never had problems. BTW for tagging music i recommend MP3Tag:http://www.mp3tag.de/en/download.html
https://linustechtips.com/topic/50067-a-little-icon-problem/#findComment-669631
Hmm. I don't then right now. If I think of something I will let you know. Good luck.
https://linustechtips.com/topic/50067-a-little-icon-problem/#findComment-669666
Check the folder properties, then the permission's - make sure none of that has been messed up.
I have also seen some maleware play with settings like that. Try running Malewarebytes, SuperAntiSpyware, Eset online scanner, etc.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/50067-a-little-icon-problem/#findComment-669775
what your looking at is called a rain meter
ExSystems
https://linustechtips.com/topic/50067-a-little-icon-problem/#findComment-669901
thanks allot the thing is this computer belonged to my brother he used some app to change the default program icons and he forgot what it was and thanks for telling me what that was
ExSystems
https://linustechtips.com/topic/50067-a-little-icon-problem/#findComment-669910
