New Build not Displaying help?
Solved by TetraSky,
The GPU is doing the same thing again, stop and starting, i made sure the 6 pins were plugged in properly. No display now
Then it's most likely DOA.
In a rare case, it could be the PSU that's faulty and not capable of outputting the current amount of power, but that could be tested if you put another GPU in there, like an old one that you own or ask a friend for one.
Alternatively, you could try the GPU in another computer. Either another PC in your home or ask a friend/family member.
