Hey Guys,
I'm looking to get my brother a wireless headset for Christmas that will work with both his PC and his PS4. This is proving to be a bigger challenge than I anticipated.
Anyone have any solutions they know will work, or am I best to just buy a wired version?
https://linustechtips.com/topic/500323-wireless-headset-for-ps4/
818 Plantronics Gamecom works well for me, got it on sale for 30 dollars during black friday.  The only issue I had with it is that the front PS4 usb ports are recessed and the dongle for the wireless connection is too large to fit normally.  I had a Female to Male usb cable however and it works just fine using that to connect to the PS4.  Haven't had any issues with it on either PC or PS4 and it comes with 10hr use on a 4 hr charge.
https://linustechtips.com/topic/500323-wireless-headset-for-ps4/#findComment-6681412
Hey Guys,
Do you have a budget?
CPU - i7 8700K / Motherboard - ROG Strix Z370 E/ RAM - 32GB Cosair Vengeance DDR / GPU  - GTX 1080ti - EVGA FTW3 / PSU - Seasonic Snow Silent 750W / Cooling - Cryorig H7 Monitor - Acer X34 Predator / Sound - Corsair Void - Case - Meshify C
https://linustechtips.com/topic/500323-wireless-headset-for-ps4/#findComment-6682029
Hey Guys,
Well with the PS4 you can plug your wired headset into the controller - so that seems a much better option than the often rubbish wireless sets
https://linustechtips.com/topic/500323-wireless-headset-for-ps4/#findComment-6688200
I have the tb 500p wireless set , you can get it fod around 89 usually, sounds great lasts about 12hrs. No issues with great sound. Just be ready for tb hate, and messages about how you can diy headset mic with some fancy cans and an attachable mic. Ps4 sony set is alright
https://linustechtips.com/topic/500323-wireless-headset-for-ps4/#findComment-6691259
Hmm what if OP has the usb headsets? Unless the ps4 controller has those too
Don't call me a nerd, it makes me look slightly smarter than you
https://linustechtips.com/topic/500323-wireless-headset-for-ps4/#findComment-6691949
Well he is looking to buy a headset - so dont buy one with USB.. obviously :P
https://linustechtips.com/topic/500323-wireless-headset-for-ps4/#findComment-6693792
I assumed OP had a headset already just one that doesn't plug into the ps4 or one that has a cord that OP doesn't want anyone tripping over
https://linustechtips.com/topic/500323-wireless-headset-for-ps4/#findComment-6694795
well he said he wants to buy one for his brother so no idea if he has one already :P, and you wont trip over a cord connected to your controller :D
https://linustechtips.com/topic/500323-wireless-headset-for-ps4/#findComment-6694859
Yeah what I meant was that if he had a wired one with usb....He would plug it into the ps4 (usb ports) and someone could trip over the wired one and send his ps4 crashing down but we don't know...So we will assume he doesn't
https://linustechtips.com/topic/500323-wireless-headset-for-ps4/#findComment-6694954
