I have an XFX R9 290 Core Edition 4GB, that I would like to flash using a modified 390X BIOS, essentially giving me a 3-5 FPS boost, as well as tightening memory timings. This is the BIOS I would like to use, suggest a better one if you'd like:
http://www.overclock.net/t/1564219/r9-390x-bios-for-r9-290-290x-now-with-stock-and-modded-voltage-tables
My GPU has Elpida chips and I want to use the modded memory timings AND the modded stock voltages, so I will use the '290_ELPIDA_MOD_1.7' BIOS. I have the ATI Flash that came with the BIOS .zip file, and I also downloaded one that I unzipped into my C: Drive, called ATIWinFlash with a bunch of DLLs and stuff. Can anyone give me a step by step guide as to how to do this? I have a basic idea but I don't want to screw it up, even if my card has dual BIOS.
Thanks!
https://linustechtips.com/topic/500222-step-by-step-guide-to-flashing/
