Storage speed question
Go to solution Solved by Thermite,
At what workload?
Copying about 5GB's of tv shows. About 20 or so different videos all together.
I have a vertex 4 from ocz that I picked up a few years ago now, and a pretty new samsung 840 evo ssd. I was doing a simple test and found that my vertex 4 which I'm pretty sure is much older than the evo drives is actually faster. Can someone tell me why the vertex 4 might be faster than a newer 840 evo drive. Both use the sata 6Gb/s connector.
This is my opinion, it doesn't mean I'm right and is liable to change at any time. I may offend of which I apologize in advance.
(Our lord and savior: GabeN)
https://linustechtips.com/topic/499964-storage-speed-question/
Age of a drive does not necessarily determine its speed and neither does the SATA generation. Just because they're both SATAIII doesn't mean they'll be equal. I mean compare a SATAIII hard drive to a SATAIII SSD.
What performance numbers are you seeing?
https://linustechtips.com/topic/499964-storage-speed-question/#findComment-6677294
vertex 4 gets about 190MB/s and the evo gets about 180MB/s. I know its not a big difference I was just curious why it was slower while it was a newer drive.
https://linustechtips.com/topic/499964-storage-speed-question/#findComment-6677329
At what workload?
https://linustechtips.com/topic/499964-storage-speed-question/#findComment-6677355
At what workload?
https://linustechtips.com/topic/499964-storage-speed-question/#findComment-6677420
