Mobo only boots with 4 pin cpu connector (in 8 pin slot)
Solved by QueenDemetria,
I don't have an extra 4/4 pin connector but this one is labeled pcie lol. None of the other cables that came with the psu would work. I almost went and bought a new psu. Should I figure out where to buy a new 8 pin / 4 + 4 pin cable then?
According to this review your PSU has two cables with the 4+4 connectors on them. Since you cut one of the cables, you can use the other unless you cut that off too. You cannot use the PCIe connector though, its a different pinout. If you don't have the other 4+4 cable, then just use the 4 pin, using an adapter will just create a weak point.
And please use standard formatting on your text, the orange is hard to read.
