Hello! I am trying to make a minecraft server with hamachi and i face some problems, one big issue is that everything is ready to join the server and when i am trying to open the jar server file it opens and it closes immediatelly,i tried to turn the eula form false to true and the opposite but there is no progress.So what should i do!
Thanks in advance!!!
https://linustechtips.com/topic/499526-minecraft-server-problems/
https://www.evolvehq.com/client
bam i just solved every fucking problem with the pice of shit hamatchi is works waaaaaaaaaaaaaaaaaaaay better, lower letancy and just over all nicer
Builds:
Hello! I am trying to make a minecraft server with hamachi and i face some problems, one big issue is that everything is ready to join the serverand when i am trying to open the jar file it opens and it closes immediatelly,i tried to turn the eula form false to true and the opposite but there is no progress.So what should i do!
also follow your topics and that dosent sound like hamatchi causing the main problem, look throuh the error log that it throws
Builds:
