First PC Build
Go to solution Solved by Gidoguy,
As of now, CSGO and Gmod mostly, but I'm looking for something that can handle H1Z1 or CoD Waw : /
yeah, this slightly altered build will be able to handle those games no problem
http://uk.pcpartpicker.com/p/29n37P
Well as the title said, this is my first PC build, and well eh, here it is?
Case: BitFenix Neos Black €44.08
http://www.dabs.ie/products/bitfenix-neos-black-silver-bfc-neo-100-kkxks-rp-B6GB.html
RAM: Crucial 8GB (2 x 4GB) Ballistix Sport DDR3 1600MHz CL9 1.5v 240pin €46.85
http://www.dabs.ie/products/crucial-8gb--2-x-4gb--ballistix-sport-ddr3-1600mhz-cl9-1-5v-240pin-bls2cp4g3d1609ds1s00ceu-7Y8S.html
Hard Drive: WD Blue 1TB Desktop Hard Disk Drive - 7200 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch - WD10EZEX €51.21
http://www.dabs.ie/products/wd-blue-1tb--desktop--hard-disk-drive---7200-rpm-sata-6-gb-s-64mb-cache-3-5-inch---wd10ezex-wd10ezex-8757.html
CPU: AMD FX6-6300 Black Edition Vishera Six Core AM3+ 3.5GHz 14MB 95W €118.96
http://www.dabs.ie/products/amd-fx6-6300-black-edition-vishera-six-core-am3--3-5ghz-14mb-95w-fd6300wmhkbox-8BXH.html
Mobo: MSI 970A-G43 - Socket AM3+ - ATX €74.95
http://www.komplett.ie/msi-970a-g43-socket-am3-atx/20185896/details.aspx
Power: Corsair 600W Builder Series CX Series CX 80+ Bronze ATX Power Supply €78.20
http://www.dabs.ie/products/corsair-600w-builder-series-cx-series-cx-80--bronze-atx-power-supply-cp-9020048-uk-8CDC.html
*Edit forgot the Graphics card* Graphics card: EVGA GeForce GTX 950 Superclocked+ ACX2.0 Gaming 2GB GDDR5 PCIe3.0 Graphics Card €203.42
http://www.dabs.ie/products/evga-geforce-gtx-950-superclocked--acx2-0-gaming-2gb-gddr5-pcie3-0-graphics-card-02g-p4-2956-kr-BL93.html
Well, the total price is 627.65. I'd appreciate if anyone told me if there was any errors or if they have any suggestions, thanks! :D
https://linustechtips.com/topic/499461-first-pc-build/
Absolutely dreadful - will not work
https://linustechtips.com/topic/499461-first-pc-build/#findComment-6672074
Might I suggest using PCPartPicker.com? Makes the process a lot easier, both for us and for you.
Other systems I've built:
https://linustechtips.com/topic/499461-first-pc-build/#findComment-6672075
Compatibility is fine, just needs a graphics card.
No, no it's not.
the FX 6300 is not worth when you can get a i5 4460 and a cheaper board for it. The CX PSU is awful for a gaming PC and if this is not a gaming PC I don't see the point of the CPU since even a Celeron is enough for an office machine
https://linustechtips.com/topic/499461-first-pc-build/#findComment-6672080
No, no it's not.
Somebody is an intel fan boy
Δ Ambassador for the Illuminati Δ
Δ "Illuminati confirmed" - Nobody  Δ
https://linustechtips.com/topic/499461-first-pc-build/#findComment-6672081
No. The 6300 is a good choice if you can only afford an i3 within the budget, but if you can afford an i5, get the i5. CX also is bad for gaming builds so he's right.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/499461-first-pc-build/#findComment-6672084
What if he can only afford that then? not everyone has lots of money to throw at a pc, I was in his situation a year ago, My fx 6300 oc'd at 4.2 GHz runs GTA V, Fallout 4 and Battlefield 4 absolutely fine.
https://linustechtips.com/topic/499461-first-pc-build/#findComment-6672091
Is it for Gaming? If so, you have to change some critical Parts.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/499461-first-pc-build/#findComment-6672094
If he can afford either that or an i3, it depends on the games he usually plays
Yeah it's for gaming, and which parts? D:
Power supply, motherboard, and the graphics card. Can you tell me, what games do you play?
https://linustechtips.com/topic/499461-first-pc-build/#findComment-6672107
Try to spend another 60$ and get a midrange i5.
And if you only can buy 1 HDD, get a decent SSD.
Also the CX PSU´s arent the best choice for Gaming Rigs.
Please edit your Post with https://pcpartpicker.com/parts/partlist/
So we can change stuff more easy.
https://linustechtips.com/topic/499461-first-pc-build/#findComment-6672117
Let's be honest, modern i3s beat the FX
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/499461-first-pc-build/#findComment-6672124
<3
Also, I'd look at different ram than the stuff I've specified in the pc part picker partslist, its too tall and will lead to compatibility issues when it comes to installing big air cpu coolers like the noctua nh-d15
https://linustechtips.com/topic/499461-first-pc-build/#findComment-6672243
https://linustechtips.com/topic/499461-first-pc-build/#findComment-6681529
https://linustechtips.com/topic/499461-first-pc-build/#findComment-6681924
