Difference between 5$ fans and 20$?
I am on a tight budget and need cooling for my system, looking at the fans, the 5$ one has a 1 year warranty and the 20$ has none. It pushes the same amount of air, is 50RPM slower and is 3db louder. Paying 15$ for 50RPM and silence seems stupid, so what is the actual difference? 5$ one is named like Arctic Cooling (I believe), 120mm.
Edit: Arctic Cooling F12 PWM is the name, and had a 6y warranty, not 1.
Is this the text below my post?
https://linustechtips.com/topic/498672-difference-between-5-fans-and-20/
Arctic cooling is fine.
I used the arctic cooling fans before, they work, are loud, and one of two failed after a few months
the air being moved wont really change, its just a matter of noise. On a budget buy the cheap fans, there are tons of cheap little mods you can do to quiet a noisy fan
Okay, but I do not really mind them being noisy, if it is cheaper. Okay, will do!
Well sometimes is that the bearing is more expensive to product, or that the product has not entered it's sales stages yet.
If the reviews are good, i don't see any reason not to get the cheaper one.
4/5 stars, the reviews that downgraded it were ones about noise and vibrations.
Just in case it bugs you, using fishing wire and mattress type foam padding to tie them into place can be surprisingly quiet (I used to be REALLY poor and used all sorts of fans and sketchy heatsinks)
Yeah that was my thought as well, because the only visual difference I can spot are the rubberized edges, which is a really easy fix. Do you know if 140mm fan slots support 120mm? The Arctic Cooling ones looked good but couldn't find them in a bigger size :(
you can always make it! otherwise no, 140 is bigger and takes up more space
Alright, since I dislike loose and spinning components I suppose it's time to check out some budget 140's. Thanks for the help!
Look into getting "rubber screws" if you want to keep fans quieter.
I don't mind it being louder if it performs the same for quarter of the price. Is not possible to use some kikd of foam/matress between the case and the fans?
dB are exponential, so 3dB more are not irrelevant. If you don't care, the cheap fans should be fine.
Yeah I know that the difference between 30 and 36 etc. is a lot more than it seems, but my current one is like 50db on idle haha
I recommend shelling out a bit more money and getting a good Noctua air cooler. Can recommend as there in one in my current build keeping my i5-6600 at a cool 39 degrees at idle. They are a really ugly beige and brown color style though...
Tokyo Sunshine:Corsair 750d case with custom lighting, Asus ROG Maximus VIII Z170, Intel i5-6600 processor, 16gb HyperX Fury DDR4 RAM, MSI r9 270x 4gb@ 1300mhz mem clock, Sandisk Ultra II SSD 256gb, 2x 1tb HDD
Yeah but that is for the CPU where I do not really mind spending money since I know it makes a difference, this was alm about the case fans. But thanks for looking out for me! :)
Ooops I thought you were talking about CPU cooler  :P
Maybe a mid range case fan... one from a known brand... but not a silence obsessed brand... something like a Corsair or Fractal.... maybe get a better bearing and longer life than a 5 buck bargain brand...that said, if the bargain brand fails in a year or two your only out 5 bucks...in summary... buy what you can afford based on needs, not what youtubers suggest or people with alot of disposable income fanboy over.  I'm pretty sure LTT made a video regarding this exact subject...
The Black Friday Rig:
[PCPartPicker part list](https://ca.pcpartpicker.com/list/QyvH8K)
**CPU** | [Intel Core i5-6600K 3.5GHz Quad-Core Processor] | $280.00
**CPU Cooler** | [Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler] | $19.99
**Motherboard** | [Gigabyte GA-Z170X-GAMING 6 ATX LGA1151 Motherboard] | $175.00
**Memory** | [Kingston FURY 16GB (2 x 8GB) DDR4-2133 Memory] | $94.99
**Storage** | [Corsair Force LE 240GB 2.5" Solid State Drive] | $85.99
**Storage** | [Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive] | $64.00
**Video Card** | [Gigabyte Radeon RX 480 8GB G1 Gaming Video Card] | $319.99
**Case** | [Corsair Carbide 400C ATX Mid Tower Case] | $89.00
**Power Supply** | [Corsair CXM 650W 80+ Bronze Certified Semi-Modular ATX Power Supply] | $84.99
**Operating System** | [Microsoft Windows 10 Home OEM 64-bit]| $109.00
 | *Prices include shipping, taxes, rebates, and discounts* |
 | **Total** | **$1322.95**
 | Generated by [PCPartPicker](http://pcpartpicker.com) 2016-11-27 18:34 EST-0500 |
