I need help choosing parts for a cheap fast gaming pc. I want a good one that runs 8GB ram in 1080p. With a good cooling system, at least 1TB memory.
1TB of Storage*
(In the tech world, Memory would typically be referring to RAM, whereas Storage would refer to your HDDs or SSDs)
Budget?
Colour preferences?
Games you want to run?
Framerate you want the g ames to run at?
Size preferences?
Noise preferences?
Need a keyboard/mouse/monitor/OS included?
so that's like 400 in parts because of the moniter/os/keyboard mouse
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor  ($112.89 @ OutletPC)
Motherboard: ASRock B85M-DGS Micro ATX LGA1150 Motherboard  ($48.99 @ SuperBiiz)
Memory: A-Data XPG V1.0 8GB (1 x 8GB) DDR3-1600 Memory  ($32.99 @ Newegg)
Video Card: PowerColor Radeon R9 270 2GB TurboDuo Video Card  ($109.99 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($36.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Monitor: Acer G226HQLBbd 60Hz 21.5" Monitor  ($89.99 @ Amazon)
Total: $560.70
Generated by PCPartPicker 2015-12-03 23:01 EST-0500
Get windows off /r/microsoftsoftwareswap or G2a
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
If you scrounge with the other parts you can get it closer to $500 since he only wants 1080p. Best place is to check the local flea market. I see 1080p monitors for $60 or less all the time. and although you won't get CherryMX keyboards and the best mice for $40, I'm using one of those funky Microsoft keyboards on my main for right now until I can get something better for a super cheap price.
COMPUTER: Mobile Battlestation  |  CPU: INTEL I7-8700k |  Motherboard: Asus z370-i Strix Gaming  | GPU: EVGA GTX 1080 FTW ACX 3.0 | Cooler: Scythe Big Shuriken 2 Rev. b |  PSU: Corsair SF600 | HDD: Samsung 860 evo 1tb
More like 250. I'd save more.
he can get like a $120 1080p moniter OS off reddit fro cheap and cheap mouse and keyboard
keyboard/mouse http://www.newegg.com/Product/Product.aspx?Item=N82E16823129036
moniter http://www.newegg.com/Product/Product.aspx?Item=N82E16824236654&cm_re=1080p_monitor-_-24-236-654-_-Product
I'm surprised this is the first time hearing about this place.
Total: $560.70
Nice Job!
I heard that I need to get Windows on my pc, do I need that, and if I do how do I get it?
Make a bootable flash drive with Windows on it using Rufus or something like that and set your BIOS to boot from the flash drive.
http://pcpartpicker.com/p/vcrKvK
im not very good at this, am i?
thousand bucks with all in, with bias towards intel/nvidia.
you can make it cheaper by going Ati route with an A10 APU. Im guessing you got the ballpark figure of 600 when comparing to a current gen console? you can also try to skip the computer monitor and connect your rig to your television, but doing web browsing on your couch during your happy time will not end well for you, if you know what i mean.
http://pcpartpicker.com/p/xgcwdC
this is close to 700 bucks. im sure you can find better deals on the monitor and operating system. APU will play most current games at a decent enough fidelity at 1080. you also have decent headroom for upgrade. another 2x4gb of ram? no problem, mobo has 4 slots. you want to play more graphically demanding games? drop in a ATI card and turn on multi gpu support. you want to run crossfire? uhh, it can be done. but why?
Total: $560.70
Replace the the R9 270 with a GTX950.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
I would actually swap the r9 270 for a 270X.
AMD causes to many Problems for my taste atm.
