Linux Help
LittleCarrot
I am trying to learn coding. I am stuck. Whats the command I need?
post-242723-0-75981300-1449113150_thumb.
"In the middle of every difficulty lies opportunity."
- Albert Einstein
The command to move up a directory is "cd .."
I actually couldn't underclock my 5 year old GPU to make it as slow as a next-gen console.
#pcmasterraceproblems
~Slick
That appears to be using the terminal, not coding...
I think you are looking for the cd command
I have been trying that.
$ cd drama/historical/
- Albert Einstein
I have been trying that. Mind tell me the exact command. They are telling me to use the CP command.
- Albert Einstein
From their Website:
Here's one more way to use cp.Navigate up one directory from drama/historical/ to drama/. (Here's a hint on how to do this.)
- Albert Einstein
From their Website:
Just "cd .." will go up one level.
I have been doing that for the past hour.
- Albert Einstein
$ cp drama/        $ cd drama        $ cp biopic/cleopatra.txt historical/                                              $ cd historical/        $ cd
Same Error
- Albert Einstein
then that website is broken
Well that sucks
It keeps saying use the cp command
- Albert Einstein
Well that sucks
that's to copy files.  That's completely different
Fucks. Linux is Complicated...
- Albert Einstein
lol not really.  Windows has those same commands actually (more or less).  You'll notice how vastly superior Linux is in that department when you start getting to more advanced things though
I like linux
- Albert Einstein
I like linux
good :)
OK, back to this, what exactly is the question currently?  If it's asking you to use cp, I'm pretty sure we've moved beyond the "move up one directory" part
good :)
i have given up on code acdemy. any vital command you can recommend?
- Albert Einstein
well you'll need the basics like cd, mv, cp, ls, cat, man, more, find, chmod, chown, grep, exit, and nano, at an absolute minimum IMO.  And operators like >, >>, and |.  That should give you a decent ability to navigate and be useful in the terminal if you ever have to limit yourself to just it.
Can You Explain Each Command?
- Albert Einstein
there are manuals for this purpose but I'll give a very quick/simple common example of each
  • cd: cd /my/folder (takes you to that location)
  • mv: mv current_name new_name (renames and/or moves a file)
  • cp: (same as mv but copies)
  • ls: ls (lists files and folders in current directory.  you may also like "ls -lta")
  • cat: cat myfile.txt (displays a file)
  • man: man cd (what you should be using on all of these :))
  • more: ls -lta | more (displays one screen of text then waits for input to continue)
  • chmod: chmod -R 755 /my/folder (changes permissions of a file or folder)
  • chown: chown -R root.root /my/folder (changes owner)
  • grep: ls -lta | grep rwx (filters output)
  • exit: exit (logs out, closes session, etc.)
  • nano: (a terminal based text editor, like vi but much less powerful and more user friendly)
And I should throw in a few more:
  • mkdir: mkdir myfolder (makes a folder)
  • rm: rm -dfr / (removes a file or directory)
  • top: top (terminal task manager)
  • killall: killall xorg (kills a process)
  • pwd: pwd (tells you where you are)
  • whoami: whoami (tells you who you are)
I'll just assume you can use su and sudo since (in the systems where relevant) that's kind of essential to get permission to do certain things.  Basically put sudo before anything to do it as root, or go sudo su root to change to root and then all things will run as root.
There's a lot more, including things like shutdown, tail, ln, ifconfig/iwconfig, lsof, rsync, which, etc. as well as platform specific things like apt-get that might come in handy but you've got the basics to be useful now.
