Hi, I want to know whether this build is good or if it needs improvements. I am still deciding on whether I should change the cpu to a i7-4790k and the gpu to a GTX 970.
http://pcpartpicker.com/p/cvGTQ7
CPU: Intel I7-5820K  GPU: Zotac GTX 970 Twin Fan  PSU: Seasonic S12II-620W Storage: WD Blue 1TB & Kingston 120GB SSD  RAM: Crucial Ballistix 4X4 16GB DDR4 2400mhz Audio: Altec Lansing MX5021, Altec Lansing VS4221, Creative SoundBlaster Roar and SoundBlaster Z  Case: Armaggeddon T1X  OS: Windows 10 Pro 64bit Peripherals: Razer Deathstalker Essential, Logitech M280, Xbox One controller with Windows Wireless Adapter
https://linustechtips.com/topic/497859-pc-build/
Get a 4690K and a R9-390.
Make sure to also get a stronger PSU and a Z97 MOBO while you're at it.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/497859-pc-build/#findComment-6653933
Looks good man, if your just buying a gaming machine keep everything you have do not go the i7. If you want to save money go for a 970. your gaming at 1080p i assume?
https://linustechtips.com/topic/497859-pc-build/#findComment-6653940
I do game at 1080p. Which is better though, the GTX 980 or R9-390X? I don't plan on gaming on 1440p as monitors are expensive.
https://linustechtips.com/topic/497859-pc-build/#findComment-6653958
Basically what @The Official Czex said
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.99 @ SuperBiiz)
Video Card: MSI Radeon R9 390X 8GB Video Card  ($419.99 @ B&H)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($44.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($103.86 @ Mac Mall)
Total: $977.79
Generated by PCPartPicker 2015-12-02 19:51 EST-0500
Rig: Thermaltake Urban S71 | MSI Z77 G45-Gaming Intel Core i5 3570K (4.4Ghz @ 1.4v) CM Hyper 212 EVO | Kingston HyperX Fury 8GB | MSI GTX 660 | Kingston 120GB SSD | Seagate 3TB HDD | EVGA 850W B2
https://linustechtips.com/topic/497859-pc-build/#findComment-6653961
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($189.99 @ Micro Center)
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler  ($42.25 @ Newegg)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($97.98 @ Newegg)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($279.99 @ Newegg)
Case: NZXT S340 (White) ATX Mid Tower Case  ($63.99 @ SuperBiiz)
Total: $971.15
Generated by PCPartPicker 2015-12-02 19:52 EST-0500
https://linustechtips.com/topic/497859-pc-build/#findComment-6653967
Thanks for the suggestions.
https://linustechtips.com/topic/497859-pc-build/#findComment-6653976
Fury>980 if im not mistaken and a SSD is really worth it, so:
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor  ($214.99 @ SuperBiiz)
Motherboard: ASRock H81M-HDS Micro ATX LGA1150 Motherboard  ($56.98 @ SuperBiiz)
Storage: OCZ ARC 100 120GB 2.5" Solid State Drive  ($39.99 @ Newegg)
Video Card: XFX Radeon R9 Fury 4GB Triple Dissipation Video Card  ($499.99 @ Amazon)
Power Supply: XFX 650W 80+ Bronze Certified ATX Power Supply  ($71.99 @ SuperBiiz)
Total: $1004.91
Generated by PCPartPicker 2015-12-02 19:54 EST-0500
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/497859-pc-build/#findComment-6653980
Everyones builds look really good here... Just my suggestion, if you can squeeze a couple more bucks out, you can switch up the gpu for a reference 980ti, which will give you wayyy better gaming performance compared to the 980. Went for a lower cost i5, but I doubt you will see any substantial gaming differences, given that they are almost identical.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B85M-DS3H-A Micro ATX LGA1150 Motherboard  ($42.98 @ Newegg)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card  ($608.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Total: $1003.92
Generated by PCPartPicker 2015-12-02 20:00 EST-0500
I like good humans and good food
https://linustechtips.com/topic/497859-pc-build/#findComment-6654027
I would defiantly go for a z97 MOBO.  That will ensure compatibility with you proc without having to do the BIOS update. There is not really a need to upgrade your Proc unless you plan on doing some content creating (photo/video editing). I would also get an SSD for your boot drive.
https://linustechtips.com/topic/497859-pc-build/#findComment-6655705
