Hi Everyone!
I have made an appearance around the forums lately, because of the fact that I will be starting a new build soon.
After lots of discussion and thinking, I want to go for a Intel Skylake i5 or i7 machine. I also have a budget of $750 without a case. I want to get the best light media, light multi tasking, and gaming machine for the money. I would prefer going with a overclockable CPU (K), but if you can justify the need not to overclock, I would be fine with an Skylake i5 or i7, With a budget of $750 without a case.
What build is the best for the $750?
Thanks,
ConfierousJelly
Main Rig 1: Intel Core i5-6600k | Cooler Master Seidon 120V Liquid Cooler | Asus Z170-AR | Crucial Ballistix Sport 8GB DDR4-2400 | Inland Professional 480GB SSD | WD Blue 1TB HDD | Zotac GeForce GTX 960 4GB | NZXT S340 White | Corsair CX 600W PSU | Windows 10 Pro | PCPartPicker Link |
Main Rig 2: Intel Core i7-6700k | CRYORIG H7 Air Cooler | EVGA Z170 FTW | Corsair Vengeance 16GB DDR4-3200 | Samsung 850 EVO-Series 500GB SSD | EVGA GTX 1070 FTW | NZXT S340 Elite Matte Black | Corsair RM 750x PSU | Windows 10 Pro | PCPartPicker Link |
Laptop: 2018 15" MacBook Pro | 2.6GHz 6 core i7 | Vega 20 GPU | Mac OS Catalina
https://linustechtips.com/topic/497150-intel-skylake-machine/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.99 @ SuperBiiz)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  ($69.89 @ OutletPC)
Video Card: MSI Radeon R9 390 8GB Video Card  ($309.99 @ Newegg)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Total: $763.33
Generated by PCPartPicker 2015-12-01 19:18 EST-0500
though if somone can get a skylake with le same preformance props to u ;)
https://linustechtips.com/topic/497150-intel-skylake-machine/#findComment-6646436
How-About-No-01.jpg :)
https://linustechtips.com/topic/497150-intel-skylake-machine/#findComment-6646441
Hi Everyone!
Thanks,
ConfierousJelly
Don't forget to follow your topics.
$750 and unlocked Skylake isn't possible, the closest I could get it is $800.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($229.99 @ Micro Center)
Motherboard: MSI Z170A PC MATE ATX LGA1151 Motherboard  ($89.99 @ Amazon)
Memory: A-Data XPG Z1 8GB (2 x 4GB) DDR4-2400 Memory  ($42.99 @ Amazon)
Total: $806.92
Generated by PCPartPicker 2015-12-01 19:26 EST-0500
$750 and locked however, is a different story.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($199.99 @ SuperBiiz)
Motherboard: ASRock H170M Pro4 Micro ATX LGA1151 Motherboard  ($87.98 @ Newegg)
Total: $746.92
Generated by PCPartPicker 2015-12-01 19:28 EST-0500
If you want the SSD, you can go with a cheaper motherboard, but it will be around $17 over $750.
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($48.98 @ B&H)
Total: $766.92
Generated by PCPartPicker 2015-12-01 19:29 EST-0500
https://linustechtips.com/topic/497150-intel-skylake-machine/#findComment-6646503
Hi Everyone!
Thanks,
ConfierousJelly
What size motherboard, mini-ITX, mATX, or ATX?
https://linustechtips.com/topic/497150-intel-skylake-machine/#findComment-6646572
ATX or mATX should work fine, if mini-ITX fits in a ATX case (Not too familiar with it), that would work also.
https://linustechtips.com/topic/497150-intel-skylake-machine/#findComment-6646682
If you have a case or a case in mind, providing that information will allow for a better build. Need to know what cpu cooling options will fit, for example.
Mini-ATX fits in mATX and ATX cases. Mini-ATX and mATX fit in ATX cases.
https://linustechtips.com/topic/497150-intel-skylake-machine/#findComment-6646916
Okay, Im looking at either the NZXT Phantom 240 or the NZXT H440. Thanks!
https://linustechtips.com/topic/497150-intel-skylake-machine/#findComment-6647807
Both of those cases take ATX motherboards. While smaller ones would fit, the build would not look very good.
There is no need to overclock unless one wants to do so. In the usage described in the OP overclocking will not really add anything. It can be fun, but it is also expensive. To fit the $750 budget, other parts that contribute to performance would have to be sacrificed to provide overclocking.
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor  ($209.99 @ SuperBiiz)
Motherboard: Gigabyte GA-Z170-HD3P ATX LGA1151 Motherboard  ($99.89 @ OutletPC)
Memory: G.Skill Ripjaws 4 Series 8GB (2 x 4GB) DDR4-2800 Memory  ($46.99 @ Newegg)
Storage: Sandisk Z400s 256GB 2.5" Solid State Drive  ($67.99 @ NCIX US)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($45.99 @ SuperBiiz)
Video Card: MSI Radeon R9 380 4GB Video Card  ($194.99 @ Newegg)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($78.99 @ SuperBiiz)
Total: $744.83
Generated by PCPartPicker 2015-12-01 23:40 EST-0500
https://linustechtips.com/topic/497150-intel-skylake-machine/#findComment-6648116
