Hey guys,
I am currently working on my first pc build and wondering if you guys think it is good or if you have any recommendations?
I am planing on using it mostly for 1080p gaming.
Here are the parts:
http://pcpartpicker.com/user/penguin2424/saved/nVTcCJ
I know the ram is overkill but I already bought it and i got a great deal.
I haven't looked into monitors yet, so the monitor listed there i don't really care about. I am looking for something that is 1080p, has a HDMI port and a VGA port, i would also prefer if it was a VESA mount compatible.
https://linustechtips.com/topic/496852-my-first-build/
Hey guys,
Here are the parts:
How much are you thinking about spending on a monitor?
https://linustechtips.com/topic/496852-my-first-build/#findComment-6643231
Hey guys,
Here are the parts:
Hows this?
Motherboard: Gigabyte GA-F2A88XM-D3H Micro ATX FM2+ Motherboard  ($44.99 @ Newegg)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card  ($179.99 @ Newegg)
Case: Corsair SPEC-01 RED ATX Mid Tower Case  ($34.99 @ Micro Center)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($80.89 @ OutletPC)
Wireless Network Adapter: Gigabyte GC-WB867D-I 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter  ($29.99 @ SuperBiiz)
Monitor: Asus VS247H-P 23.6" Monitor  ($99.99 @ Newegg)
Total: $729.70
Generated by PCPartPicker 2015-12-01 11:00 EST-0500
THE R9 380 OUT PERFORMS THE 960!!!
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/496852-my-first-build/#findComment-6643254
Hows this?
Total: $729.70
thanks,
I monitor looks like a good deal and I want the 960 because i like some of the benefits the 960 has, especially nvidia GameStream, because i have a nvidia shield tablet.
https://linustechtips.com/topic/496852-my-first-build/#findComment-6643291
Your graphics card has ports, the hdmi etc. on the mobo is just for when you're using on board graphics. FX-6300 uses AM3+.
If you make a post contradicting mine that doesn't directly address my claims, or cites 'facts' without evidence, I'm probably not going to bother responding to it, because you probably didn't bother reading my post properly, and because life is too short. It doesn't mean I don't have an answer for you. It means I'm not dignifying you with a response.
https://linustechtips.com/topic/496852-my-first-build/#findComment-6643375
socket on motherboard (the place where your cpu fits). Search for motherboards and filter by am3+, or use pc part picker which removes incompatable options.
https://linustechtips.com/topic/496852-my-first-build/#findComment-6643412
I just built my computer yesterday with a FX-6300 and a R9 380
http://linustechtips.com/main/topic/483614-build-log-desk-build-home-theater-build/page-2
You can see it come together there and I explained a bit of my adventure. I also showed a benchtest score from Firemark.
Just showing in case it helps you make the decision.
Monitor + Headphones + Keyboard + Computer
Under $620
https://linustechtips.com/topic/496852-my-first-build/#findComment-6643474
Hey guys,
Here are the parts:
what about this. I don't know if you wanted to include ram into the build cost considering you already bought it. As for windows, just buy it off reddit for 20$
PCPartPicker part list: http://pcpartpicker.com/p/9cpL3C
Price breakdown by merchant: http://pcpartpicker.com/p/9cpL3C/by_merchant/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($174.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B85M-DS3H-A Micro ATX LGA1150 Motherboard ($39.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($45.99 @ SuperBiiz)
Video Card: Zotac GeForce GTX 970 4GB Video Card ($319.99 @ Micro Center)
Case: BitFenix Neos ATX Mid Tower Case ($49.99 @ Amazon)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply ($39.99 @ Amazon)
Monitor: Acer G226HQLBbd 60Hz 21.5" Monitor ($89.99 @ Amazon)
Total: $760.93
Generated by PCPartPicker 2015-12-01 11:46 EST-0500
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/496852-my-first-build/#findComment-6643521
Total: $760.93
It looks like a great build but buying windows for $20 off reddit seems kinda sketchy, and the monitor isn't what i'm looking for. Also, i'd like to stick with a CPU that I could potentially over-clock in the future.
https://linustechtips.com/topic/496852-my-first-build/#findComment-6643584
reddit is fine, i know lot of people who have used it.
I just put a random monitor that matched the price of the one in your build btw.
edit :if you want to oc, look into buying an older cpu like the 3770k off ebay, that's what i did.
https://linustechtips.com/topic/496852-my-first-build/#findComment-6643610
Ok thanks,
I haven't really used reddit before, can you link the reddit page where i would buy it?
https://linustechtips.com/topic/496852-my-first-build/#findComment-6643633
Ok thanks,
https://www.reddit.com/r/microsoftsoftwareswap/
haven't used it myself, but i've only heard good things about it.
still ask around just in case
https://linustechtips.com/topic/496852-my-first-build/#findComment-6643697
