So a few days ago random times my pc froze up forcing a hard reset. I tried re seating my ram and gpu to see if it would fix the problem and it did for some time, but the freezing started happening again and the same solution fixed it. I have a feeling it may happen again, any ideas on why this is happening?
"The ability to destroy a planet is insignificant, next to the power of the force"
Kirito (Main Build):
CPU Intel Core i5-6600k OC'd @ 4.6 GHz Motherboard ASUS Z170-AR RAM 16GB Corsair Vengeance LPX 2400 GPU ASUS STRIX 1070 Case Phanteks Enthoo Pro Storage Samsung 850 EVO 250GB, WD Green 2TB & Travelstar 1TB PSU Corsair CS550M Cooling Corsair H110i GT Keyboard Razer Blackwidow Chroma Mouse Razer Naga Epic Chroma Sound Sennheiser HD280 Pro OS Windows 10
Asuna (My Laptop): Razer Blade Stealth
CPU Intel Core i5-7200U w/ Hyperthreading RAM 8GB Hardwired into the system GPU I N T E G R A T E D   G R A P H I C S  Storage Samsung 960 EVO m.2 120GB Cooling Fans yo Keyboard Razer Blackwidow Chroma Mouse Razer Naga Epic Chroma Sound Sennheiser HD280 Pro OS Windows 10
Yui (My mini server):
TBD
https://linustechtips.com/topic/496845-strange-freezing/
Motherboard?
Give me a boost.
https://linustechtips.com/topic/496845-strange-freezing/#findComment-6643224
Asus M5A99FX pro r2.0
TBD
https://linustechtips.com/topic/496845-strange-freezing/#findComment-6643240
Run Memtest 86 to see if it is a ram problem.
and run FurTest or Unigine Valley/Heaven (monitor the GPU temps)
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
https://linustechtips.com/topic/496845-strange-freezing/#findComment-6643279
I did both already with no issues or errors found
TBD
https://linustechtips.com/topic/496845-strange-freezing/#findComment-6643506
I also used to get the BSOD stating "SYSTEM_SERVICE_EXCEPTION" and "IRQL_LESS_OR_NOT_EQUAL_TO" both linking to ntoskrnl.exe when these problems arose
TBD
https://linustechtips.com/topic/496845-strange-freezing/#findComment-6643562
Its just noted as a critical shutdown due to loss of power, which normally happens when i hold the power button or press the reset button
TBD
https://linustechtips.com/topic/496845-strange-freezing/#findComment-6643601
