Hey guys so i want to get more ram for my pc. I have 2x4gb kingston hyperx fury red atm. Im wondering if i can buy the black version of their ram. Is it the same and just a different color or does it have different voltage/speed? Also will i just be able to plug it in and its good to go or do I have to configure it in some way. Any help is appreciated.
Thanks
PC specs:
-i7 4790k
-r9 280x
-evga 750w psu
-8gb kingston hyperx ram
-120gb ssd
-1tb hdd
https://linustechtips.com/topic/496380-help-adding-ram/
yeah, it should be fine if it's the same speed and timings are listed. you don't need to configure it
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/496380-help-adding-ram/#findComment-6638411
