Define s side panel for non-side panel case
I was curious if there was somewhere I could buy an after market window for my define s? I bought the non-windowed and I think I want to have it now. :D I know the fractal store doesn't ship to the US. Unless I'm wrong in which case YAY. (Get it? Case? Ha.)
01101100 01110110 01101100 00100000 00110101 00100000 01101101 01100001 01100111 01101001 01101011 01100001 01110010 01110000
https://linustechtips.com/topic/496345-define-s-side-panel-for-non-side-panel-case/
I don't think they sell the window separately, but you could send an email to Fractal and see if they could get you one.
Pro Tip: don't use flash when taking pictures of your build; use a longer exposure instead. Prop up your camera with something (preferably a tripod) if necessary.
if you use retarded/autistic/etc to mean stupid please gtfo
In the US I think that Puget systems sells parts for fractal.
I think that the Define S takes the same panel as the R5 which they stock here:
https://www.pugetsystems.com/store/item.php?cat=Replacement+Parts&id=10880&com=d41d8cd9&que=fractal%20define
I'd double check that first however or take a closer look around the site and see if they list the Define S parts seperatly.
Hope this helps!
