My planned build is with an NZXT S340 on my desk to the right of my keyboard, mouse and monitor. I have noticed that it is quite a tall case, and I'm not sure how I would route the cables neatly, particularly for headphones/headsets. Any suggestions? Is there something I'm missing?
https://linustechtips.com/topic/496328-cable-routing/
Just adding to my previous point, the S340's front audio + USB ports are on the top so it would mean the cables would hang across me really irritatingly.
i have a phanteks enthoo pro M, similar case, quite tall ineed, and the I/O is off to the side, but almost at the top of the case
i just keep my front io clean, and route everything to the back, even my headphone jack.
i jam it behind my monitor and under my desk with zip ties and some double sided sticky tape
i hate staring at some cables in the front of my case.
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/496328-cable-routing/#findComment-6637852
Part of the problem is that I'm planning to get the HyperX Cloud 2 headset, which has a USB soundcard and volume thingy that sits on your desk. I suppose I could route the cable round from the left of my monitor and mirror tape the soundcard to my desk...
https://linustechtips.com/topic/496328-cable-routing/#findComment-6637910
thats what i would do, i would not want a little dongle sliding around, id tape that sucker down
https://linustechtips.com/topic/496328-cable-routing/#findComment-6637946
Ideally I would get a wireless headset with controls on the ear cup. The Logitech G930 is the only headset in a similar price range, but I've heard mixed things about it. Some people say it's brilliant, and others say "eh". What are your thoughts?
https://linustechtips.com/topic/496328-cable-routing/#findComment-6637979
