Can someone finish this plz? Max 1000 to 1100 CAD.. HAving trouble finding a MOBO I have no idea what to look for. Thx
Will be used for gaming and microsoft office.
http://ca.pcpartpicker.com/p/wghtZL
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($49.99 @ Canada Computers)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.99 @ Canada Computers)
Video Card: MSI Radeon R9 390 8GB Video Card  ($422.95 @ Vuugo)
Total: $851.41
Generated by PCPartPicker 2015-11-29 17:49 EST-0500
https://linustechtips.com/topic/495668-need-mobo-for-build/
Yes that's H97
B85 would probably also be fine. I wouldn't go for H81 though.
Why? It's just some don't have USB 3.0 headers. :P
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/495668-need-mobo-for-build/#findComment-6631160
Ima go with H97 because it has the highest number.. GG
Just because it has the highest number doesn't mean it'll perform any better. But if you can afford a nice H97 board, be my guest and go with it.
Sig under construction.
https://linustechtips.com/topic/495668-need-mobo-for-build/#findComment-6631196
This is why I posted a topic. But I always get a lot of suggestions but I have a hard time choosing the right part. What would you get? The B85?
https://linustechtips.com/topic/495668-need-mobo-for-build/#findComment-6631215
I'm cheap so I would probably get the B85 board assuming it's cheaper. However you should go with a board that has all the features you want and H97 is much more likely to have more of those features.
https://linustechtips.com/topic/495668-need-mobo-for-build/#findComment-6631313
