Thermal throttling damaging card?
Solved by OddsCrazyStuff,
Recently MSI After burner has been starting my pc with my GPU fans turned off. I keep forgetting to them on before a playing certain games. League and csgo don't seem to make the fans kick on but I do notice stuttering sometimes while playing that reminds me to turn them on. I was curious if this throttling has or would damage the card severely? I've run some test and everything seems OK. Just worried I may have screwed up. Never had this issue before. Gonna uninstall and reinstall afterburn or just get something new!
Thermal throttling is the cards way to prevent damage. So you should be fine.
Aldo, a lot of heat over a long period of time can reduce the lifespan of the card.
