what monitor should i get?
cruztony
I will be using 980ti sli for my set up. Im looking for a high refesh monitor (if posible bigger than 28 inches) could be ultra wide or not as long as it is 1440p. Thanks
Edit: any alternatives to acer predator x34?
2, 3 or 4 way SLI? Budget?
i5 6600K @ 4.4GHz / Cooler Master Nepton 240M (GC Extreme Thermal Compound) / Asus Maximus VIII Gene / 8GB Corsair Vengeance LPX DDR4-2400 / 240GB SanDisk SSD Plus & 2TB SeaGate Barracuda HDD / EVGA GTX 980 ACX 2.0 / XFX XTR 750W 80+ Gold  / Fractal Design Node 804        Total: £1042.31
2 sli, i wouldnt like to go over a grand.
https://www.asus.com/uk/Monitors/ROG-SWIFT-PG279Q/ It's 27" which is unfortunate but here are the specs if you want them:
  • 27-inch, WQHD 2560 x 1440 resolution display feature IPS technology for wide 178-degree viewing angles and lifelike gaming visuals
  • World-first 165Hz refresh rate and NVIDIA®G-SYNC™ technology for seamless visuals and smooth gameplay
  • ASUS-exclusive Ultra-Low Blue Light, Flicker-Free, GamePlus, and GameVisual technologies provide a comfortable gaming experience
  • Ergonomically-designed stand with full tilt, swivel, pivot, and height adjustment for comfortable viewing position
Sorry, I couldn't find a response time but you didn't state what you wanted for that in your post.
http://www.amazon.com/Acer-XB270HU-bprz-27-inch-Widescreen/dp/B00UPVXDA8/ref=as_li_ss_tl?ie=UTF8&qid=1435435822&sr=8-1&keywords=acer+xb270hu&linkCode=sl1&tag=jokerprodu03-20&linkId=X54AWXSHE4XTKHJC i would take this over the asus rog swift pg278q because it is tn and the xb270hu is ips.
you could also look at the x34 if your willing to pay that extreme price tag
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
Thanks for the advice. I always come across this monitor. But i kind of find it to be small for my taste. I should look in to it anyways. Thanks
Thanks for sharing. do you know if there is any alternative or something close to ace x34?
no way.. it is something new.. 3440x1440 and 100hz with g sync
The LG 34UM95 and 34UM97 are ultrawide 3440*1440 and I think they're a little cheaper. The 97 is curved and the 95 is flat
