This is my first time building a computer. I wanted something that could run games like Company of Heros and also be good for a little Photoshop and sound editing. I am not a professional, I just like to play around. I'd like to know what you think.
CPU: Core i5-4460
Cooler: Corsair H80i GT
Motherboard: MSI H97M-G43
RAM: Corsair Vengeance DDR3-1600
Storage: Kingston SSDNow V300 (boot drive)
              WD Blue 1TB 7200
Video: MSI GeForce GT740
PSU: SeaSonic X 400
CD/DVD: Asus DRW-24D3ST
https://linustechtips.com/topic/494406-first-build/
CPU: Core i5-4460
              WD Blue 1TB 7200
PSU: SeaSonic X 400
The build is really unbalanced. You need to spend less on your CPU cooler and get way better graphics. I would recommend using PC partpicker for choosing parts :http://au.pcpartpicker.com/
PC is Intel Core i5 6400, GIgabyte H170 Gaming 3, Corsair Vengeance LPX 2x4GB 2400Mhz ,Sandisk Ultra Plus 128GB, WD Blue 1TB, NZXT S340, ASUS Geforce GTX 960. Fractal Design Tesla R2 650W. http://au.pcpartpicker.com/p/793XNG. Graphics card choices don't always have to be dictated on performance. If you want the game stream and power consumption of the GTX 970 get that. If you want raw performance of the R9 390 get that. In the end we are all gamers, so what if your buddy gets an extra 5 fps?
https://linustechtips.com/topic/494406-first-build/#findComment-6618257
Give us a budget (in your currency) and we can help you build one :)
If you have the option to get a high refresh rate monitor, do it.
Main PC CPU: i7 14700k CPU Cooler: NZXT x62 280mm Motherboard: Gigabyte Aorus Elite X WiFi 7 GPU: Asus Strix 3080ti RAM: Gskill Trident Z5 32gb DDR5 SSD: 990 Pro 2TB, 980 Pro 1TB Case: NZXT S340 Black PSU: Corsair RM1000e ATX3.0
Server: CPU: i7 9700k RAM: Corsair 32gb DDR4 HDD: 36tb Usable SSD: Samsung 500gb NVME Case: Fractal Define R5 PSU: Corsair RM1000e ATX3.0
https://linustechtips.com/topic/494406-first-build/#findComment-6618269
4460 doesnt need to be Watercooled, a stock cooler will do, but probably just get 212EVO
Make sure the RAM is 8GB, 16GB is better
For the SSD get Samsung 850 PRO instead of that
dont buy ssd
nigga u srs ? SSD is mostly a need now, since everything is huge
Key Switches Guide | LLT Beginner Guide | GPU TDP & Power Consumption Explained | PSU Tier
s a d b o y s 2 0 0 1
https://linustechtips.com/topic/494406-first-build/#findComment-6618299
http://pcpartpicker.com/p/XWh2Jx
Something I quickly threw together. Much better than your rig.
CASE: NZXT S340 CPU: Intel i5-4690K MOBO: Gigabyte GA-Z97X RAM: Corsair 16GB GPU: MSI R9 390 HDD: WD Blue 1TB SSD: Samsung 850 EVO 250GB PSU: XFX ATX12V/EPS12V 650W
https://linustechtips.com/topic/494406-first-build/#findComment-6623220
CPU: Core i5-4460
              WD Blue 1TB 7200
PSU: SeaSonic X 400
as a general rule, your gpu should be more expensive than your cpu. get an i3
https://linustechtips.com/topic/494406-first-build/#findComment-6623496
