Which one is better? help
Go to solution Solved by leadeater,
Normally I go with brand trust when it comes to ssds. AData would be my preferred brand between those 2 but it looks like the Patriot has significantly better MTBF.
Stuck between 2 possible ssds for installing os and maybe a game:
Prices are identical, Patriot Blast 120gb http://www.ncix.com/detail/patriot-pbt120gs25ssdr-blast-series-120gb-af-112712-1259.htm
or the Adata SP550 120gb http://www.ncix.com/detail/adata-sp550-120gb-2-5-sata3-fa-111657-1259.htm
 Is there a difference, which one is faster, quiter(if thats even possible), cooler?
Or is the choice just gonna be base on appearance?
https://linustechtips.com/topic/493362-which-one-is-better-help/
