whats wrong with my gpus fan?
Ethre
If you just maxed the fan speed nothing
As far as what? The sound of the motors?
ye once the fan hits 57% some weird sound starts coming out of the gpu
it almost sounds as something is hitting something
listen closely
once i hit the fan to 57%
it starts making this weird sound, which is definately not normal
it also happens when i game, once i game for like 10 minutes
It might be one of the bearings.
is it possible to fix it
What are you doing that the fan goes past 50%?
If it sounds like it's hitting something, see what it's hitting and move it.
If anyone asks you never saw me.
If you want to get edgy, you could take apart the cooler and possibly try lubricating the fan to see if that fixes the issue. Otherwise, send it back to MSI. I'd also inspect the cooler for any kind of obstructions that may be more obvious with the fan spinning at a faster rate.
thats the thing nothing is hitting it
the first time i heard it was after i was playing far cry 4 for like 20 minutes
I'd listen to Godlygamer. If you don't see anything it could be hitting contact MSI.
