i have a budget of $200 i can spend a little more if its worth it and i need some headphones / headset for my pc
if its possible i would like them to be compatible with my PS4, i did some research and looked at a few reviews online
and so far these are the 4 headset i like the most sennheider pc 363D, audio technica ath-adg1, v-moda crossfade m-100 and the beyerdynamic custom one pro... can you guys advise which is better or give me a recommendation
thanks.
http://www.amazon.co...t/dp/B008O515CK
http://www.amazon.co...t/dp/B00H8NS1K8
http://www.amazon.co...e/dp/B00A39PPDK
http://www.amazon.co...e/dp/B00PK2LJ4E
https://linustechtips.com/topic/491801-headset-advice/
