Hello,
So i tried turning on my system, and i noticed i was getting a black screen. Trued rebooting, and it took really long. First the windows loading screen. Then a black screen, then another loading screen, then nothing. I tried several times, but it seems the system crashes during the second loading screen, whatever profile i use on my gpu.
I tried using my integrated graphics.
The system boots like normal, until i get to the login screen. The screen is grey-green with stripes going vertically and the screen is off center. This cant be fix by going to the desktop.
I cant access my bios, as only a quarter of the bios screen is displayed. The booting up process seemed very slow these few days : loading screen, then black screen, then another loading screen, then the login screen(even my laptop with a 5400rpm drive does that in a fraction of the time).
Help. I really need this computer for school and i need to know if i need to replace or rma any components.
The overclocks on both cpu and gpu have been stable for months, and i was playing crysis 3 earlier on it without any problems.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/491665-system-not-reaching-login-screen/
Hello,
Since your integrated graphics are having issues too, I'd suspect your monitor or cable
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
But my computer crashes when i use my gpu, so that shouldn't be the problem?
Try turning all Overclocking off while troubleshooting.
Boot your system into safe mode. Remove your GPU drivers completely and re-install the latest drivers.
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
How am i supposed to do that if i cant access anything.
I just remembered that i had installed radeon software crimson before i started having the problem.
You might be able to boot into safemode
And like I said, you can also try a different monitor and cable
If you're overclocking under windows, It's unlikely the changes are persistent through reboots.
Coming back to boot in safe mode.
i did a system restore ( i should've thought of that first) and it worked .thanks !
