Hi, please could you recommend some nice micro-atx cases below, if possible link PCPP please, thanks! Also the smaller the better but with good cooling, thanks
CPU: Intel i7-4790k | Cooler: Corsair H110i GT | Motherboard: MSI Z97I AC  | Graphics Card: SAPPHIRE R9 280  | http://uk.pcpartpicker.com/p/pszsdC
http://adamredfern.co.uk
http://rewinded.co.uk
http://yewtreeservices.co.uk/
http://asiat.co.uk/
http://ssstelecom.co.uk
http://hndrx.co.uk/
http://wisemove4u.com/
https://linustechtips.com/topic/491578-best-micro-atx-case/
This is one of the best -> http://pcpartpicker.com/part/bitfenix-case-bfcprm300kkwskrp
I have owned this case and it is surprisingly nice to work in. The window is a nice touch if you're into that. The Prodigy M line has like a million colors so you can pick whichever you like. The handles are also a really nice touch.
This case is also an awesome choice -> http://pcpartpicker.com/part/thermaltake-case-ca1d500s1wn00
I have less use with this case as I did a build for a friend with it so he has used it mainly. I will say that the air flow in this case is superb and temperatures in the case were barely higher than in FULL towers I have used, which is really saying a lot.
https://linustechtips.com/topic/491578-best-micro-atx-case/#findComment-6590785
My first link isn't working for some reason so here it is again http://pcpartpicker.com/part/bitfenix-case-bfcprm300kkwskrp
Thanks for that, yeah I really like this case. Do you have any experiences with it? :D
http://asiat.co.uk/
http://hndrx.co.uk/
https://linustechtips.com/topic/491578-best-micro-atx-case/#findComment-6590822
Why yes I do  :)  It was actually my main case for about 5 months when I would go to lan events at college. I had a 4790k with a h100i gtx liquid cooler and it still never felt too crowded in there. Temps were fine but obviously not as cool as larger cases. Having a liquid cpu cooler like Corsair's can help bring down overall system temps a lot. A blower styled gpu is actually the best option here if you wanna keep overall temps down as well. It really is an awesome little case.
https://linustechtips.com/topic/491578-best-micro-atx-case/#findComment-6590876
Thanks that really helps, also is it huge because alot of people say its big? Thanks or am I getting confused with the mini-itx version? :)
http://asiat.co.uk/
http://hndrx.co.uk/
https://linustechtips.com/topic/491578-best-micro-atx-case/#findComment-6591006
It would help to know what kind of hardware you plan on stuffing into a (specifically) MicroATX case.
http://pcpartpicker.com/part/corsair-case-cc9011069ww
http://pcpartpicker.com/part/corsair-case-cc9011070ww
I'd recommend looking at the Air 240. With the appropriate hardware, it will provide excellent cooling in one of the most stylish cases available.
https://linustechtips.com/topic/491578-best-micro-atx-case/#findComment-6591545
