The performance increase is marginal to none. Hoped for more, but it's still an improvement overall.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/491485-radeon-crimson/#findComment-6589315
following... I really want to know what people think of this.  I really would like to get the opinions of someone who's played on both teams so we can get a comparison between this and nvidia's software.
https://linustechtips.com/topic/491485-radeon-crimson/#findComment-6589438
Just out of curiosity, what are your thoughts on crimson so far? I, for one, am loving the new layout and features.
Think it's worth the upgrade? If so, do you reckon I should uninstall my previous drivers first or just install crimson over top?
Other systems I've built:
https://linustechtips.com/topic/491485-radeon-crimson/#findComment-6590922
Yeah it's definitely worth the upgrade, the only time you would need to uninstall your old drivers is if they were malfunctioning, just install Crimson over them.
https://linustechtips.com/topic/491485-radeon-crimson/#findComment-6590957
Yeah it's definitely worth the upgrade, the only time you would need to uninstall your old drivers is if they we malfunctioning, just install Crimson over them.
Cool, will do. Thanks :)
https://linustechtips.com/topic/491485-radeon-crimson/#findComment-6590975
I love a few things.
AUTOMATIC MOTHERFREAKING UPDATES!
The new design is amazing.
The new Displays windows shows settings for all monitors.
It lets you overclock you monitor.
Per game overclocking.
a few things I don't like.
To actually change any of the "other/advanced" settings it still opens CCC (But some tabs have been removed(I suspect this will be until they port all the settings into their new UI))
The Display Tab doesn't have a resolution setting.
The Display Tab doesn't have a refresh rate setting.
The advanced eyefinity option are done through CCC still and are slower than ever.
CPU Overdrive is gone. :-(
But whatever they've done to the driver it initializes way quicker. My boot to desktop time dropped significantly. Also Haven't had a Catalyst has crashed and recovered message (Yet)
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
https://linustechtips.com/topic/491485-radeon-crimson/#findComment-6592391
Looks and functions exactly the same on Linux.
Not exactly..... This version natively supports 4.x kernels...
It also happens to perform a lot worse in some games under Linux.
https://linustechtips.com/topic/491485-radeon-crimson/#findComment-6596090
That is based off my personal experience so far.
Yeah I was being pedantic...
I was defiantly sad that they didn't have the new QT interface on Linux.
https://linustechtips.com/topic/491485-radeon-crimson/#findComment-6600994
