I finally Did My solid window Mod. I had some 1/4" Lexan Kicking around so the Mod Cost next to nothing. I Like it. How About you guys?
Anyone doing this i highly recommend 1/4 inch or 5mm Lexan (Polycarbonate) or acrylic. Don't waste your time with Plexiglas its melting point is to low and chips out and cracks when being tooled. It also scuffs very easily.
1. 1/4 inch think is easier to work with(cut and drill) than 1/8
2. There is less space to make up on the back(screw) side.
CPU: FX-8350 Cooler: NZXT Kraken X60 w/2X NF-A14 FLX MoBo: Asus M5A99FX Pro Rev 2.0 Memory: 8GB G.Skill Sniper@1720 GPU: Sapphire Dual-X HD7970@1100/1500 Storage: Samsung 840 120GB(OS), Seagate Barracuda 1TB 7200 64MB PSU: Sparkle 850W Gold Case: Corsair C70 Military green w/ Solid window Keyboard: Ducky Shines 3 (MX Blues), Razer BlackWidow 2013 Ultimate Mouse: Corsair M90,M65 w/ Vengeance MM600
https://linustechtips.com/topic/49104-my-corsair-c70-solid-window-finished/
Looks really good, I personally hate those windows with the fan mounts and the mesh/holes in the actual window... looks terrible
Intel 4770k EVGA GTX 780 Gigabyte Z87X-UD3H Corsair Vengeance Pro Samsung EVO (RAID0) Corsair Air540 Seasonic SS-660XP2
EK Supremacy Alphacool NexXxoS Swifttech MCP655 Swifttech MicroRes PrimoChill PrimoFlex Tubing Alphacool Compression Fittings NXZT Hue LED Controller
Asus PB278Q Acer H233H Coolermaster Quickfire Corsair M60 FiiO E09K Beyerdynamic DT-770 Pro Windows 7
looks nice I personally don't see the point in a window if they add fan mounts it ends up looking worse than a plain black panel
| 3570k @ 4.4.ghz | Hyper 212 evo | 8GB (2x4GB) 1600mhz Corsair Vengeance | Gigabyte Z77X UD3H | Corsair CX750M | Corsair 300R | OCZ 240GB SSD | Seagate 1TB 7200rpm HDD | Asus DCUII 7950 @1150mhz core 1600mhz mem
| BenQ XL2411T | Corsair Vengeance K60 | Logitech G700 | steelseries Qck+ | Fiio E10 | Zalman clip on mic | HD 598 | ATH-M50 |
Yeah I hated not being able to see my Components very well. Haven't decided if im going to light it yet.
To me those fan mounts were just another entrance for dust into my rig.
Thanks. wasn't to bad but I have real good tool set up. Drill press makes this mod so much easier.
Corsair should offer this. Mostly everyone hates it
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
Not a very time consuming mod. took me about 2 hours.
Nice job! :D
AMD FX-8320 @ 4.3 ghz | Corsair H60 (Push/Pull)|  8GB Kingston Hyper X DDR3 1.6 ghz | Sapphire HD 7870 Oc'd | Biostar TA970 MOBO OCZ 750w  PSU | 2TB HDD + 120gb Kingston V300 SSD| Coolermaster CM Storm Enforcer Case | SoundBlaster Audigy SE  Windows 7        "I am a leaf on the wind, watch me..."   "You know nothing Jon Snauhh" "Take the risk of thinking for yourself, much more happiness, truth, beauty, and wisdom will come to you that way."
/Steam Profile/Folding@home stats/TekSyndicate Fourms/  \m/  RIP David Gold (1980-2011) \m/ RIP Peter Steele (1962-2010) \m/ RIP Chuck Schuldiner (1967-2001) \m/ RIP Dio (1942-2010) \m/ RIP Cliff Burton (1962-1986) \m/ RIP Dime (1966-2004)
