My 650D Build in Progress
Guest King of Old School
Hey Guys  :)
My Current Build atm
Motherboard: ASRock Z77 Extreme 4
CPU: intel i3 2130
CPU Cooler: Noctua NH-U12S
Memory: Kingston 1333MHz 8GB
Graphics CardGigabyte GeForce GTX 650 OC
Sound Card: ASUS DG
SSD Drive: OCZ Solid 3 120GB
Hard Drive: Seagate Barracuda 1TB
Sound Card: ASUS DG - Changing this too
If you guys would like to give me some advice on my future upgrades please feel free to give me some pointers i would be so thankful.
I think i did a good enough job on the Cable Management, I know there is still some more places i still need to fix up inside the case.
Thank You for reading my post  :D
https://linustechtips.com/topic/49079-my-650d-build-in-progress/
Hows the clearance for the cooler?
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/49079-my-650d-build-in-progress/#findComment-652975
Wow that is really overkill on the PSU. Upgrades depend a lot on how much you're willing to spend but here are some tips:
CPU: intel i3 2130 - Don't bother upgrading unless you're getting a high end GPU too
RAM: Low end Kingston but will be upgrading this too - what do you mean low end? frequency and timings don't really matter much since you're running a discrete GPU with dedicated memory. I'd recommend 8GB of it though.
Video Card: Gigabyte GTX 650 - Highest priority but wait until AMD releases Volcanic islands GPUs before making a decision.
Sound Card: ASUS DG - Changing this too - you'd probably be better of spending the money elswhere but Xonar DSX offers really good bang for he buck for a mid range card if you really want to.
Hard Drive: OCZ Solid 3 120GB upgrading this as well - depends on how many writes it has had (judging by the fact that it was released 2 years ago I'm guessing that's not a problem), you probably won't see enough of a difference to upgrade as long as you have TRIM turned on.
Back to the build, good job on the cable management, that looks really clean, you should consider sleeving the GPU cables too, especially if you get a card with two connectors, that would look really sharp.
https://linustechtips.com/topic/49079-my-650d-build-in-progress/#findComment-654446
Hey Guys :)
CPU: intel i3 2130 - but i will upgrade to a i5 3570K when i have the cash
Video Card: Gigabyte GTX 650 - Will be upgrading this next month but haven't worked out which one yet
Hard Drive: Seagate 1TB
id say go for gtx 770 Kingston hyperx ssd and case fans make difference some corsair af fans
System Specs~~~~~
Case-Corsair Air 540                                   CPU-i7 4770k                           Ram-Corsair Vengeance 16 Gbs    PSU-Corsair RM1000
Motherboard-Asus Maximus VI Formula    Graphics-Asus Gtx 780 Ti x2     CPU Cooler-Corsair H100i               SSDs-Corsair Force GS 128/360 Gb
https://linustechtips.com/topic/49079-my-650d-build-in-progress/#findComment-654464
With the RAM its only 1366, but its 8GB tho but i'm looking to buy some 1800 ram, i'm look to buy Corsair Gen2 White Sleeved Modular Cable Kit, I will have to check to see if i have TRIM turn on.
Thanks for your Advice
https://linustechtips.com/topic/49079-my-650d-build-in-progress/#findComment-655861
Hey a 770 would be nice but we get ripped off in Australia for computer parts but i'm thinking about buying one from ebay and trying to save $50.00, with the SSD i'm looking at a Samsung but i will keep the Kingston in mind i'm wating on Noctua to release the black fans.
https://linustechtips.com/topic/49079-my-650d-build-in-progress/#findComment-655876
unless ur goin for the pro version or Evo jus buy Kingston also noctua black fans if u want to wait
System Specs~~~~~
https://linustechtips.com/topic/49079-my-650d-build-in-progress/#findComment-655947
I'm guessing you mean 1066? If you're just gaming you probably won't see much difference even going to 1600/1866 or even higher, so if you really want to upgrade it make sure it's a much lower priority than the rest of the parts you mentioned.
https://linustechtips.com/topic/49079-my-650d-build-in-progress/#findComment-656095
Yeah i was going to the pro but since they have come out with the evo i think i will end up going with the evo, yeah i can wait for the black noctua fans
Thanks again
https://linustechtips.com/topic/49079-my-650d-build-in-progress/#findComment-656339
The ram i have is 1333 (i just check the ram) but i could be wrong tho, i do other things on the computer apart from gaming i also do video encoding as well but i don't think the ram will help with that tho
Thanks again
https://linustechtips.com/topic/49079-my-650d-build-in-progress/#findComment-656349
  • 5 weeks later...
  • 2 months later...
My build is still in progress
The Old Build
CPU: intel i3 2130
Sound Card: ASUS DG
The New Build
Motherboard: MSI Z77A-GD65
CPU: Intel Core i5 3570K
Memory: G.Skill Ares 1866MHz 8GB
Graphics Card: EVGA GeForce GTX 760 Superclocked
Solid State Drive: Samsung SSD 840 EVO 250GB
Hard Drive: Western Digital WD Black 2TB
maybe to some people its not much of an upgrade but i'm still happy with it Still planning on more changes, here are the pictures of the current build.
I think my cable management is getting better, but meh i don't know if it can be any better tho
Thanks for looking
post-35368-0-66333000-1385608374_thumb.j
post-35368-0-36283100-1385608406_thumb.j
https://linustechtips.com/topic/49079-my-650d-build-in-progress/#findComment-1112843
Very good job on the cable management.
You should change the color of the '860' on the PSU to blue :D
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
https://linustechtips.com/topic/49079-my-650d-build-in-progress/#findComment-1113024
I'm pretty sure you can get a free backplate from EVGA.  You should do that, the GPU looks a little saggy  :ph34r:
Thanks for that i'm not sure how i would get one do i just have to look on the EVGA website.
Update: i checked on the EVGA website and the Free Back plate ended at the end of September but you can buy them tho so i will end up buying one for about $30.00 AUD
yeah i wouldn't mind doing that, i think i would be nice if Corsair release a black and blue stickers for the AXi series PSU's, Thanks for the advice
https://linustechtips.com/topic/49079-my-650d-build-in-progress/#findComment-1113499
  • 2 weeks later...
