Sapphire R9 Fury Nitro would fit perfectly in that build
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/490226-help-me-name-my-rig/#findComment-6574561
I need some help naming my PC I am totally blank on names. and if you could suggest a GPU for ~$600 USD that would be awesome too.  I love the aggressive looking graphics cards
980Ti http://pcpartpicker.com/part/msi-video-card-gtx980ti6gd5toc
Virtus. Got it from a game, if you know then you're cool ;)
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/490226-help-me-name-my-rig/#findComment-6574564
I want to say that is Dota or Runescape
i5-6600k | Current GPU:GTX 970 | FireStrike Score with said GPU: 10752 Proof
https://linustechtips.com/topic/490226-help-me-name-my-rig/#findComment-6574583
ROONSCAPEEEE :D
Old Rig
https://linustechtips.com/topic/490226-help-me-name-my-rig/#findComment-6574601
