H440 LED STRIP HELP?
Go to solution Solved by Dobbsjr,
Please don't write in all caps. :)
As for recommendations, NZXT's Hue+ looks pretty good, but it's a bit expensive. Bitfenix alchemy led strips are also a good choice.
Hello everyone :D
Just wondering how do I install led strips to my NZXT H440 and what will I need to do so? I want one strip at the very top and one at the bottom of the side window.
Would be amazing if you could recommend some strips and what is needed :)
Thanks (ps another question is inbound soon)
Might add this later...
https://linustechtips.com/topic/489869-h440-led-strip-help/
Did my post help you? Then make sure to rate it!
Check out my post on symbolic links! || PSU ranking and tiers || Pokemon Thread
https://linustechtips.com/topic/489869-h440-led-strip-help/#findComment-6571032
$100 for LED's & a box in your pc... I'll pass, but the Alchemy 2.0 looks amazing! Thanks :D
https://linustechtips.com/topic/489869-h440-led-strip-help/#findComment-6571065
