http://pcpartpicker.com/p/LxwdLk
All I really do with computers is play CS:GO. Is this computer good at its price to play on highest settings? I already have a 144hz 1080p monitor
I went with one stick because it was cheap, plus i can upgrade later. I went with an ssd because i thought itd help with speeds. 250gb since all I do is CSGO boii. 550w supply so it can last a while and be upgradeable
https://linustechtips.com/topic/489786-csgo-machine/
I'd keep the 1 X 8GB Stick.
That way you dont have to switch out the 2 X 4GB sticks when you want more.
https://linustechtips.com/topic/489786-csgo-machine/#findComment-6570193
Should be fine for csgo :)
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
https://linustechtips.com/topic/489786-csgo-machine/#findComment-6570195
Try get an i3 somehow, source games are EXTREMELY CPU dependent and I'm highly against AMD for competitive CSGO or TF2. For source games, the CPU is the last thing you want to skimp on in my opinion.
The SSD is useful, it helps keep random stutters down which can sometimes kill you in CSGO if you're unlucky.
System specs
  • Graphics card: Asus GTX 980 Ti (Temp target: 60c, fan speed: slow as hell)
  • CPU: Intel 6700k @ 4.2Ghz
  • CPU Heatsink: ThermalRight Silver Arrow Extreme
  • Motherboard: Asus Maximus Viii Gene
  • Ram: 8GB of DDR4 @ 3000Mhz
  • Headphone source: O2 + Odac
  • Mic input: Creative X-Fi Titanium HD
  • Case: Fractal Design Arc midi R2
  • Boot Drive: Samsung 840 Pro 128GB
  • Storage: Seagate SSHD 2TB
  • PSU: Be quiet! Dark Power Pro 550w
Peripherals
  • Monitor: Asus ROG Swift PG278Q
  • Mouse: Razer DeathAdder Chroma (16.5 inch/360)
  • Mouse surface: Mionix Sargas 900
  • Tablet: Wacom Intuos Pen
  • Keyboard: Filco Majestouch Ninja, MX Brown, Ten Keyless
  • Headphones: AKG K7xx
  • IEMs: BrainWavs S1
https://linustechtips.com/topic/489786-csgo-machine/#findComment-6570209
go intel as cs go is a very cpu based game. you dont need a 250gb ssd for cs go. a 120 will be way more than enough.
http://pcpartpicker.com/p/Tj6JK8
this is much better
My rig: r7 1700 @ 3.9/1.35v, 16gb ddr4 3200, assorted rando SSDs, hx 1050, vega 64 1650/1025
MY $75 BUILD https://linustechtips.com/main/topic/576889-the-75-build-log/#comment-7547280
https://linustechtips.com/topic/489786-csgo-machine/#findComment-6570226
this is much better
ECS makes bad motherboards
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/489786-csgo-machine/#findComment-6570239
I was just thinking that, atleast spend a bit more and don't get a dirt cheap motherboard, most cheaper boards are still ok though, OP.
System specs
Peripherals
https://linustechtips.com/topic/489786-csgo-machine/#findComment-6570242
https://linustechtips.com/topic/489786-csgo-machine/#findComment-6570250
