I would like to my PC into a Hackintosh. Dual Boot it if possible. I would like to know how and what i need to do.
Here are my PC Specs:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($359.99 @ Micro Center)
Motherboard: Asus MAXIMUS VIII HERO ATX LGA1151 Motherboard  ($219.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($79.99 @ Micro Center)
Video Card: Asus GeForce GTX 980 Ti 6GB STRIX Video Card  ($654.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($103.86 @ Mac Mall)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($90.18 @ Amazon)
"In the middle of every difficulty lies opportunity."
- Albert Einstein
https://linustechtips.com/topic/489010-hacintosh-help/
In the time it took you to make that list, come to the forums, make this post.. take that and cut it in half, maybe quarters and that's the time it would have taken you to Google and read 5 guides on how to do it because the first link on Google is a "Always up to date Hackintosh guide" that has 100% of everything you need to know.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562530
I am wondering is all hardware supported?
- Albert Einstein
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562555
Well I can garuntee the CPU cooler is fully supported by OSX... Jokes aside, This isnt really a question you need answered. This is you wanting us to do the work for you. All you have to do is just type the part name, and hackintosh into google and its pretty easy to find if its compatible.
Don't do drugs. Do hugs!
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562572
Skylake processors are not supported at the moment. Initial support has been provided by the new El Capitan release, but nobody has actually been able to boot successfully and no real Macs have Skylakes in them yet either. Since Skylake processors don't work yet, we have no idea whether or not that motherboard will either and we won't be able to tell until Skylake support is introduced. Right now, using a Haswell processor is still a great option.
All of your other parts should work. Just make sure to download the latest version of the NVIDIA Alternate Graphics Drivers since Maxwell-based cards need that driver for full acceleration.
A full guide on how to prepare your USB, how to install OS X and how to use the post-installation tools correctly can be found here. When planning to do Hackintosh builds, its always a good idea to refer to the TonyMacx86 Buyers' Guide for a list of hardware that has been verified to work natively with OS X.
"Daddy's going on a dangerous mission to shoot his employees." -Linus Sebastian 2014 (src)
"I believe in French Fries. I believe in America. I believe in the Union." -Luke Lafreniere 2015 (src)
"I have pockets in all my shorts." -Luke Lafreniere 2015 (src)
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562579
What parts should I be worried about being compatible?
Couldn't that be possible by having different boot drives or am I overthinking this? I don't know I've never bothered with dual boot.
I plan on doing that once I can assure all my part are working
Skylake processors are not supported at the moment. Initial support has been provided by the new El Capitan release, but nobody has actually been able to boot successfully and no real Macs have Skylakes in them either. Right now, using a Haswell processor is still a great option.
When should I expect? I already bought these parts.
- Albert Einstein
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562594
Okay, sorry if that came off as a little harsh. Since your a begginer, you will want to make sure your motherboard, graphics card and cpu are compatible. The rest doesnt really matter.
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562613
Any sites that you recommend to check compatibility?
- Albert Einstein
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562631
You will want to make sure that your CPU, GPU and motherboard is compatible. The rest still do matter (even something like an older PCI device can prevent your system from booting in to OS X), but those three are the major ones.
Dual booting Windows and OS X is as simple as booting in to your prepared Hackintosh USB, opening Disk Utility, configuring the drive you wish to install OS X on, and select that drive in the setup wizard.
We don't know exactly when full native Skylake support will be introduced. It could easily be introduced within the next three or four months to ~1 year. If you already purchased the motherboard and CPU, I recommend returning them and purchasing parts that are listed on TonyMacx86's Buyers' Guide.
Like I said, the TonyMacx86 Buyers' Guide is great. All of the parts listed there have been tested and proved to work natively with OS X.
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562635
I dont know of any one stop website thats gonna tell you everything. Like I said you can just google the name of the part and hackintosh and find out pretty fast for individual parts. If your shopping for new parts for it, i'd reccomend looking at succesfuly made hackintoshes on pcpartpicker since you know those builds worked.
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562638
http://www.tonymacx86.com/building-customac-buyers-guide-november-2015.html
All of the parts listed here have been tested and proved to work natively with OS X. In addition, builds are also listed here (They call their builds 'CustoMacs')
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562646
This is more of a side project.
- Albert Einstein
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562647
The Majority of my parts are not supported
If you're referring to that list, you're don't have to pick that specific RAM kit or that specific SSD.
The types of parts that don't really matter in Hackintoshing are Storage, PSU, Case, RAM, CPU Coolers, Monitors, Keyboards, Mice, etc.
The three main components that really DO matter are: CPU, GPU, Motherboard.
All of your components should work except your CPU and motherboard.
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562670
Are ROG motherboard usually supported?
- Albert Einstein
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562679
Sadly no, not usually, if I recall correctly. Like I said earlier, there's no way of knowing whether or not your specific board will work until Skylake support is introduced.
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562736
Is the Maximus VII supported? That is my other build with the i7 4790K
- Albert Einstein
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562823
Yes! The VII Hero, VII Ranger, VII Gene and VII Impact all work natively on OS X.
If you went to the TonyMacx86 Buyers' Guide and scrolled down to the Motherboards section, you'd see those mobos listed.
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562831
Are you running a hackintosh? You seem so knowledgeable
- Albert Einstein
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562887
Thanks! hehe
Yes, I dual boot Windows 10 and OS X 10.10.
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562892
What are your system specs?
  • CPU Intel Core i5-4670
  • Motherboard MSI Z97 PC MATE
  • RAM Team Dark Series 16GB (2x8GB) DDR3-1600
  • GPU EVGA GTX 960 SuperClocked
  • Case Enermax ECA3253-BL
  • Storage 2x Kingston SSDNow V300 Series 120GB, 1x Western Digital Caviar Green 3TB 3.5" 5400RPM, 1x Seagate ST3000DM001 3TB 7200RPM
  • PSU Cooler Master eXtreme Power Plus 500W ATX Power Supply
  • Cooling Stock case fans, stock CPU heatsink
  • Keyboard Self-Refurbished IBM Model M, Apple Wired Keyboard w/ Numeric Keypad
  • Mouse Insignia 5-Button Wireless Mouse, Apple Mighty Mouse
  • Operating System Windows 10 Pro, OS X 10.10 (Yosemite)
  • PC Part Picker URL http://ca.pcpartpicker.com/user/Skyber21/saved/x3gxFT
It was a budget system, but I still love it!
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562917
Is my PC Stronger than the lowest tear mac pro
- Albert Einstein
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562923
Maybe. You can use benchmark sites, as well as CPUBoss and GPUBoss to find out. I'm not that familiar with using Apple hardware, the only thing that Apple makes that I like enough to use is their operating system.
https://linustechtips.com/topic/489010-hacintosh-help/#findComment-6562937
