Hey folks,
My gf needs a new laptop. She uses Allplan in college and needs a laptop that's powerful enough to power it. The problem that i have when searching for a suitable laptop is that i don't know what components of a PC/laptop are important to run Allplan properly. So i hope you guys can help me. You can also leave lpatop suggestions up to 900€, but less is better.
who cares...
https://linustechtips.com/topic/488749-help-laptop-for-allplan/
They actually have a dedicated PDF for that: https://www.allplan.com/fileadmin/user_upload/_corp/Launch2016/PDF/EN/System_requirements_Allplan_2016.pdf
They recommend workstation graphics but pricing for those usually starts at 1200€ so your best bet it to buy the strongest Laptop you can find (and return  ;) ) and test out if it runs.
Did you know this forum has an unofficial/official Star Citizen group? Head over to our organization's page, numerous forum threads or our LTTC Discord Server to find out more.
https://linustechtips.com/topic/488749-help-laptop-for-allplan/#findComment-6559521
Yeah, I've already seen the recommended spec PDF and its kind of pathetic honestly.
I would rather like to know what PC component the workload is distributed onto and get a good laptop according to that. But sadly nobody seems to know if its cpu or gpu bound and whether Geforce gpus are actually relevant or not, regardless of what allplan says..
who cares...
https://linustechtips.com/topic/488749-help-laptop-for-allplan/#findComment-6559945
