Router Storage Help
Solved by techguru,
Can anyone recommend me a router that will work with my WD mybook 4TB (http://www.amazon.co.uk/Book-USB-Hard-Drive-Backup/dp/B00G28Y96K/ref=sr_1_1?s=computers&ie=UTF8&qid=1448044061&sr=1-1&keywords=WD+mybook+4TB).
It has a USB 3.0 connector but the routers I have tried have not detected it
any of the asus AC routers that you can install the asus merlin firmware on
for my suggestion
ac56u or ac66u or ac68u
